Convert model to step by apprentice server
infoQN6A6
infoQN6A6
Hi everyone,
I need to create a configurator for a client. For the client is not important to have Inventor or other software. To be "cheap" I want use apprentice server or other (if you know) .net tool to create parts and assemblies, applies colors and at the end export the model as STEP.
I read the documentation and apprentice doesn't allow to export as STP so my client need to buy Inventor.
Do you know a way to create an automation like this?
I prefer Inventor because I can crete parametric parts and assembly. I created some automation like this to create belt conveyor and using Inventor is simple.
Valerio Pittavino
Simply, use a Task Scheduler -> export.
infoQN6A6
Ok,
but task scheduler needs to have Inventor so my client must buy a licence of Inventor, right?
If I have Inventor is not a problem to do all, I am interested to find a solution cheaper for my client. I revealed in advance to my client that he must buy a licence but if I find another solution is good.
Valerio Pittavino
I do not know.
