Convert iAssembly/iPart to normal part
Is it possible to convert iAssembly/iPart factory to normal assembly using iLogic?
I've found the way to delete single rows and columns, but how can I delete the entire Table?
Is this function available through API?
bradeneuropeArthur
Dim a As Application
Set a = ThisApplication
Dim b As PartDocument
Set b = a.ActiveDocument
Dim c As iPartFactory
Set c = b.ComponentDefinition.iPartFactory
c.Delete
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
THANK you!
C-Hoppen
Hello
the code works well with iParts. Deleting an iAssembly table always always throws an exception.
Inventor.AssemblyComponentDefinition assmDef = assmDoc.ComponentDefinition;
            if (assmDef.IsiAssemblyFactory)
                Inventor.iAssemblyFactory factory = assmDef.iAssemblyFactory;
                factory.Delete(); // throws an exception
Is there any solution?
Regards
Christoph
Edit: Second try with vba:
bindlmi
not sure, if you still need help, but I had the same problem. The problem were excluded ComponentOccurrences in the iAssembly. Delete them or include them before deleting the iAssemblyFactory and you're fine.
Regards
Michael
