Convert from iLogic to VBA
jake_egley
jake_egley
I need to convert the following iLogic into a vba format that I can put in a macro. Can anyone help me? Also is there a resource for doing this myself? Thank you
iProperties.Value(oModel, "Custom", "Height")=Measure.ExtentsHeight
iProperties.Value(oModel, "Custom", "Width")=Measure.ExtentsWidth
iProperties.Value(oModel, "Custom", "Length")=Measure.ExtentsLength
oHeight = iProperties.Value("Custom", "Height") oWidth = iProperties.Value("Custom", "Width") oLength = iProperties.Value("Custom", "Length")
Jake Egley
Inventor 2022
hollypapp65
Sub Main()
Dim oPropsets As PropertySets
Dim oPropset As PropertySet
Dim oProp As Inventor.Property
Dim oDoc As Document
oDoc = ThisDoc.Document
oPropsets = oDoc.PropertySets
For Each oPropset In oPropsets
	Logger.Info("+" & oPropset.DisplayName)
	Logger.Info("-" & oPropset.Name)
	For Each oProp In oPropset
		Logger.Info(" +" & oProp.DisplayName)
		Logger.Info(" -" & oProp.Name)
	Next
Next
'oPropset = oPropsets.Item("Design Tracking Properties")
'Logger.Info(oPropset.Item("Creation Time").Value.ToString)
'oPropset.Item("Creation Time").Value = Now
End Sub
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GUID-PropertySets
Curtis_Waguespack
@jake_egley, here is a VBA example
Sub iProps()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As ComponentDefinition
    Set oDef = oDoc.ComponentDefinition
    Dim oCustomPropSet As PropertySet
    Set oCustomPropSet = oDoc.PropertySets.Item("Inventor User Defined Properties")
    Dim propNames As Variant
    propNames = Array("Height", "Width", "Length")
    Dim propName As Variant
    For Each propName In propNames
        On Error Resume Next
        Dim prop As Property
        Set prop = oCustomPropSet.Item(propName)
        If Err.Number <> 0 Then
            ' Property doesn't exist, so create it
            oCustomPropSet.Add "", CStr(propName)
        End If
        On Error GoTo 0
    Next
    ' Setting the properties - remove the Set keyword for numeric values
    oCustomPropSet.Item("Height").Value = oDef.RangeBox.MaxPoint.Z - oDef.RangeBox.MinPoint.Z
    oCustomPropSet.Item("Width").Value = oDef.RangeBox.MaxPoint.X - oDef.RangeBox.MinPoint.X
    oCustomPropSet.Item("Length").Value = oDef.RangeBox.MaxPoint.Y - oDef.RangeBox.MinPoint.Y
    ' Getting the properties
    Dim oHeight As Double
    Dim oWidth As Double
    Dim oLength As Double
    oHeight = oCustomPropSet.Item("Height").Value
    oWidth = oCustomPropSet.Item("Width").Value
    oLength = oCustomPropSet.Item("Length").Value
    MsgBox (oHeight & "x" & oWidth & "x" & oLength)
End Sub
Curtis_Waguespack
see this link
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-BDDB44A3-3415-44EB-B10E-216BB08BD614
Skadborg.NTI
ChatGPT (or Gemini/CoPilot, etc.) excels at code conversion. However, it is not particularly reliable for generating iLogic code from scratch—it often fabricates API calls that are invalid. Nonetheless, it is quite effective for code conversions.
jake_egley
This ended up working for getting the overall length and width in VBA
                Set oDTProps = oDoc.PropertySets.Item("Design Tracking Properties")
                oWidth = oDTProps.Item("Sheet Metal Width").Value
                oLength = oDTProps.Item("Sheet Metal Length").Value
Jake Egley
Inventor 2022
