Hi All,
I have some problem with the mini toolbars.
In many cases when I want to work with selected enities the best place for custom commands should be the Contextual Mini Toolbar or a Custom Mini Toolbar.
1. Primarily I would like to customize the contextual mini toolbar using the OnContextualMiniToolbar event. It works fine if I select objects manually or using command from the ribbon but if I change the selection using a custom command from an active contextual mini toolbar then the mini toolbar dissapears and not appears again in context of newly selected entities.
ContextualMiniToolbar01.jpg: I select an edge manually and add my custom command to the mini toolbar. It works great.
ContextualMiniToolbar02.jpg: I click my custom command and add more edges to the selection -> no mini toolbar. Why?
ContextualMiniToolbar03.jpg: I select the same edges manually -> the min toolbar appears again (I didn't add custom command to it in this case)
2. If I use my own minitoolbar then I have to face with another problem: how can I add original commands (for example fillet or chamfer) to my own mini toolbar?
Thanks in advance.
Attila Farkas
