Context for publication- Inventor Presentation
mjkoushik
mjkoushik
In PresentationDocument class, ActivePublication property requires ("Context") as argument. I would like to know how publication and presentation document is related and what is the required "context" as argument.
g.georgiades
Publications are basically fully featured Scene objects, both of which are children of the Presentation document.
After much digging, I was not able to determine what the context variable should be. (There is a lot of goodies hidden in the document attributes, but none worked...)
However, I was able to find a suitable workaround I believe to access all the publications without using SelectSet. This operates on two principles: The model browser scene nodes return PublicationObject type and no Scenes can have the same names (Inventor throws an error if you try to name them the same). Therefore, I am able to get a list of all publication objects and also determine the active publication.
Note this code is iLogic and can be run using the new 2023 ribbon buttons.
Dim doc As PresentationDocument = ThisApplication.ActiveDocument
Dim pubs As New List(Of Publication) 'Essentially PresentationDocument.Publications
Dim topnode = doc.BrowserPanes.Item("Model").TopNode
For Each node As BrowserNode In topnode.BrowserNodes 'These are all the scene nodes
	If node.NativeObject IsNot Nothing AndAlso TypeOf node.NativeObject Is Publication Then
		pubs.Add(node.NativeObject)
	End If
Next
Dim activePub = pubs.First(Function(p) p.DisplayName = doc.ActiveScene.Name) 'Essentially PresentationDocument.ActivePublication
