[iLogic] How to open drawings of the selected components in assembly ?
王承之pmhker
Advisor Advisor
Message 1 of 9
王承之pmhker
I want to run a ilogic rule and select components in assembly browser, then open drawings of them.
Here is my existing code,However, it can only open drawings in the same folder as the part。
how to edit the code to open drawings in all folders in a workspace。
thanks
Imports File = System.IO.File
Imports Path = System.IO.Path
Sub main
Dim oAsmDoc = ThisDoc.Document
If oAsmDoc.DocumentType <> kAssemblyDocumentObject Then
 MsgBox("Must running in an assembly!", , "Pmhker")
 Return
Dim oDoc As AssemblyDocument = ThisDoc.Document
oCompDef = oDoc.ComponentDefinition
Dim oSet As HighlightSet = oDoc.CreateHighlightSet
Dim comps As ObjectCollection
Dim comp As Object
comps = ThisApplication.TransientObjects.CreateObjectCollection
While True
 comp = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter,"Select components,Press_Esc_to finish select")
 If IsNothing(comp) Then Exit While
 comps.Add(comp)
 oSet.AddItem(comp)
End While
For Each comp In comps
 ofile = comp.Definition.document
 ofilename = ofile.fullfilename
 fullname = Path.ChangeExtension(ofilename, ".idw")
 If File.Exists(Path.ChangeExtension(fullname, ".idw")) Then
  ThisApplication.Documents.Open(fullname, True)
  'ThisDoc.Launch(fullname & IDWType)
Else
	MsgBox("Drawing of" & ofilename & "can't found",,"Pmhker")
Next
End Sub
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
王 承之
Autodesk AGN [Inventor 俱乐部] Leader
Inventor Club | Bilibili
AGN L    EESignature
Replies (8)
Message 2 of 9
j.brodersen
Hi @王承之pmhker
the problem is
it has the path to the folder where your parts are saved,  so this line
will lock for the idw in the same folder.
Do you save your idw files always in the same location like eg
ThisDoc.WorkspacePath & "\MyDrawings\
 if so following could do the job
Sub Main
 Return
drwPath = ThisDoc.WorkspacePath & "\MyDrawings\" 'Change MyDrawings to the name of the folder where your drawings are saved and ThisDoc.WorkspacePath if the drawings aren't saved in the project location
Dim comp As Object
While True
 comps.Add(comp)
 oSet.AddItem(comp)
End While
 'to get only the filename without path
 justFilename = Right(ofilename, Len(ofilename)-InStrRev(ofilename, "\", -1))
 fullname = Path.ChangeExtension(justFilename, ".idw")
 If File.Exists(drwPath & fullname) Then
  ThisApplication.Documents.Open(drwPath & fullname, True)
Else
Next
End Sub
Message 3 of 9
王承之pmhker
thanks for your reply。
but the name of folder that drawings saved is not always the same. Maybe some are in “WorkspacePath\DrawingA\"  and some are in “WorkspacePath\DrawingB\"
王 承之
AGN L    EESignature
Message 4 of 9
nedeljko.sovljanski
Hi @王承之pmhker
Use AssemblyDocument.ReferencingDocuments to list Inventor document where your file is used. Filter only drawing type, and be aware your assembly can be used in more than one drawing.
Message 5 of 9
j.brodersen
@王承之pmhker
I butchered your code a little bit and following worked for me
Sub Main
 Return
drwPath = ThisDoc.WorkspacePath & "\" 'Change MyDrawings to the name of the folder where your drawings are saved and ThisDoc.WorkspacePath if the drawings aren't saved in the project location
Dim comp As Object
While True
 comps.Add(comp)
 oSet.AddItem(comp)
End While
Dim drwfolder As String
Dim dirs As String()
Dim dir As String
Try
 dirs = System.IO.Directory.GetDirectories(drwPath)
     For Each dir In dirs
		If  System.IO.File.Exists(dir & "\" & fullname) Then
        drwfolder = dir
Next
Catch
    drwfolder = ""
End Try
If drwfolder = "" Then
MsgBox("Drawing of" & ofilename & "can't found", , "Pmhker")
Return
Else
  ThisApplication.Documents.Open(drwfolder & "\"  & fullname, True)
Next
End Sub
  I'm sure that a few lines can be simplified like using dir.contains(fullname) instead of system.IO.File.Exists but I'm unfortunately not experienced enough to get it working
Maybe you can figure it out if you check following link
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/opening-drawing-directly-from-model-...
there I found the pieces i needed  for the "loop through all sub folders" part
Message 6 of 9
王承之pmhker
When I run this rule, an error is displayed in line 63
王 承之
AGN L    EESignature
Message 7 of 9
j.brodersen
@王承之pmhker
can you share the error message and did you change something because line 63 is empty with me?
Message 8 of 9
王承之pmhker
And it can't open darwing  in the same folder as the part
王 承之
AGN L    EESignature
Message 9 of 9
j.brodersen
@王承之pmhker
ok sorry but my chines is not existing so i can only assume which kind of error you got 😅
Just tried to move the .idw to differed folder locations (including the one where the part file is located) in the project path but i can't get the code to "crash" /give me an error, it opens the idw each time of the part I've selected. Only exception was when the idw was directly in the WorkspacePath folder, there i got the msgbox you added when no idw was found for the prt
Could you try to copy the code and insert is again? From my side it looks like that one line is missing somewhere because I've a total of 70 lines and with you it's ending at 69.
It would as well be interesting to know what
is on your end because that's the only thing I think could cause the error. If everything works fine drwfolder should show you where the idw is located (In your case the folder where the parts are)  and fullname the name of the idw file it selfe.
