Content Center File Naming issue (FDS Ultimate 2014)
3DAli
3DAli
I'm trying to place a retaining ring from content center and it has some file naming protocol issue. I tried to edit the library but unfortunatelt standard libraies are all read only.
is there any way to fix this? I checked and the problem is for both S37 and 37 type it uses the same file naming pattern. so if I insert one or the other first it doesnt let me to insert the second one.
Dennis.Ossadnik
Autodesk Support
Autodesk Support
Hi 3DAli,
you are right. Standard Content Center is read only. But only as long as they are not copied to a custom library.
Copy affected family to your read/write library
Then switch Library view to your library
Edit family table and now you are able to change the file naming scheme
Does this workflow help?
Dennis Ossadnik
Senior Technical Support Specialist
3DAli
Hi Dennis
Thanks for your advice to work around this, it definitely help for now till Autodesk fix the problem.
your help and support is very much appreciated
Sincerely
Ali
