Content Center Component Change Size on multiple selected, but not all, members
checkcheck_master
checkcheck_master
Placing Content Center Components with AutoDrop is great.
But what if I want to change the size on 20 from 100?
See picture, what happend to the button Change Size when I select more than one member?
A.Acheson
The change size button gets removed from the user interface. for more than one occurrence selected. You can use the replace form content center command which will replace those that are selected.
I can only assume it is because the size command finds the family connected with the occurrence and changes the member (hence the family dialogue is immediately opened) but does not deal with multiple occurrences due to the potential for different families to be present.
Regards
Alan
checkcheck_master
Thanks A.Acheson, I never noticed the feature, good to know.
