Replace Model Reference unable to update
will_roe
will_roe
I'm trying to get some code to work to make a workflow as easy as possible for non inventor users using a design calculator.
Current workflow (we use vault but are avoiding it in this scenario)
Copy .ipt and .idw from master folder into new folder
Rename files to the same unique filenames
open .ipt
once inputs are complete click button that runs the below rule-
'opens drawing with same filename
Try
 oIDW = ThisDoc.FileName(False) & ".idw"
 ThisDoc.Launch(oIDW)
Catch
 MessageBox.Show("No Drawing Found", "Title")
End Try
Drawing opens
below rule triggers on open
'replaces model reference with same file name but with .ipt
oDoc = ThisDoc.Document
oFilepathext = ThisDoc.ChangeExtension(".ipt")
Dim oFD As FileDescriptor
oFD = oDoc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor
oFD.ReplaceReference(oFilepathext)
InventorVb.DocumentUpdate()
 The model reference shows correctly in "Replace Model Reference" but the view doesn't update.
The sheet has the lightning bolt like it needs updating but it won't let me update anywhere (I've also tried getting to update with a ilogic rule)
If I save and close it and reopen it fixes the link but this is a step I want to avoid.
Any help appreciated.
CattabianiI
Have you tried Sheet.Update?
oDoc.Sheets.Item(1).Update()
I think it has the same behaviour of
but could please give a try to oDoc.Update()
oDoc.Update()
will_roe
Hadn't tried it but, it didn't work ☹️
A.Acheson
You will need to change the initial workflow in windows. Once you lose a reference only a manual linking will re-establish this.
What works:
Copy both files and rename then open the new drawing. Run the replace reference rule and your done. Delete the old files then if you need. You can set this all to be done in the rule if you want.
Windows renaming is not best practice unless you know what will fail etc, so to reduce the error put all the copy/save as/rename work/replace reference in the rule. The drawing in this case is the top level so renaming that is fine where as the part is referenced internally in the drawing so renaming the part breaks the link.
Drawing:
What is happening:
Internal information stored (part I am referencing is test1) After a rename of the part it goes to look for the reference and has no knowledge of the rename and will not find the file. The rule will not work until the original links are established
Regards
Alan
will_roe
So I'm not sure why but moving the rule to an external rule and triggering it with a rule has seemed to fix the problem.
iLogicVb.RunExternalRule("REPLACE MODEL REF WITH SAME FILE NAME")
I also tried the below for the drawing open button but couldn't quite figure it out
'If the drawing open button hadn't been pressed before it will open the drawing, replace the reference save, close & reopen it. This worked when i did it manually.
Dim idwPathName = ThisDoc.ChangeExtension(".idw")
Dim oDrawDoc As DrawingDocument
If RESOLVED = False Then
	ThisApplication.Documents.Open(idwPathName, True)
		oDrawDoc.Save
		oDrawDoc.Close()
RESOLVED = True
ElseIf RESOLVED = True Then
