Having trouble with a parts list rule.
Brian.Price
Brian.Price
I have an ilogic rule that I run to remove, add, and sort my parts lists. But for some reason it doesn't always work.
I made a template using a frame generated assembly with a general drawing. I then ilogic copied the drawing and model to new folders for the different sizes that I am going to make. I then open each model and drawing and edit them to the correct dimensions then I complete the drawing. But every once in a while the parts list rule shows and error and won't run. I can seem to figure out why. Any help on this is greatly appreciated, thanks in advance.
Here is the rule:
Sub Main
	Partslist
	Renumber
	PLSTYLE
End Sub
Sub Partslist
'Create or replace Partslist
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawingDoc.ActiveSheet
Try
Dim oPartslistCheck As PartsList
oPartslistCheck = oSheet.PartsLists(1)
partslistpresent=True
Catch
partslistpresent=False
End Try
If partslistpresent=True
        Dim oPartsList As PartsList
        oPartsList = oDrawingDoc.ActiveSheet.PartsLists.Item(1)
        oPartsList.Delete
    Dim oDrawingView As DrawingView
    oDrawingView = oSheet.DrawingViews(1)
    Dim oBorder As Border
    oBorder = oSheet.Border
		xMax = oBorder.RangeBox.MaxPoint.X - 0
		yMax = oBorder.RangeBox.MaxPoint.Y
		xMin = oBorder.RangeBox.MinPoint.X
		yMin = oBorder.RangeBox.MinPoint.Y
Dim oPlacementPoint1 As Point2d
    	oPlacementPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(xMax, yMax)
    Dim oPartsList1 As PartsList
		oSheet.PartsLists.Add(oDrawingView, oPlacementPoint1)
		oPartsList1 = oDrawingDoc.ActiveSheet.PartsLists.Item(1)
		PLxrev = (oPartsList1.RangeBox.MaxPoint.X -oPartsList1.RangeBox.MinPoint.X)
		PLyrev = (oPartsList1.RangeBox.MaxPoint.Y -oPartsList1.RangeBox.MinPoint.Y)
		oPlaceX = xMax
		PL_Style = Parameter("PL_Style")
		If PL_Style = "ICM Parts List - Lower Right" Then
			oPlaceY = yMin + PLyrev + 2.8575
		If PL_Style = "ICM Parts List - Upper Right" Then
			oPlaceY = yMax
oPlacementPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(oPlaceX, oPlaceY)
oPartsList1.Position = oPlacementPoint2
oPartsList1.Sort("DWG# /TAG#")
oPartsList1.Renumber
oPartsList1.SaveItemOverridesToBOM
oPartsList1.Style = oDrawingDoc.StylesManager.PartsListStyles.Item(PL_Style)
Dim oPartList As PartsList
oPartList = oDrawingDoc.ActiveSheet.PartsLists.Item(1)
Dim i As Long
For i = 1 To oPartList.PartsListRows.Count
oCell = oPartList.PartsListRows.Item(i).Item("CUT LENGTH")
oCell2 = oPartList.PartsListRows.Item(i).Item("CUT_LTH")
If oCell2.Value = "" Then
oCell.Value = ""
Next
End Sub
Sub Renumber
Dim oPartList As Partslist
Dim i As Long
oCell.Value = ""
Next
'oPartList.Sort("ITEM", True)
oPartList.Sort2("ITEM",True,"ITEM",True,"ITEM",True,True, True)
oPartList.Renumber
oPartList.SaveItemOverridesToBOM
End Sub
Sub PLSTYLE
Dim openDoc As Document
   'assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.ActiveDocument
    'Set a reference to the active sheet.
    Dim oSheet As Sheet
    oSheet = oDrawDoc.ActiveSheet
    'Look for partlist within drawing. End rule, if it doesn't exist.
    'say there is a Partslist on the sheet.
    Dim oPartslist As Partslist
    oPartslist = oSheet.PartsLists(1)
    'set parts list to a specific style
	If PL_Style= "ICM Parts List - Upper Right" Then
	oPartslist.Style = oDrawDoc.StylesManager.PartsListStyles.Item("ICM Parts List - Upper Right")
	If PL_Style= "ICM Parts List - Lower Right" Then
	oPartslist.Style = oDrawDoc.StylesManager.PartsListStyles.Item("ICM Parts List - Lower Right")
End Sub
JelteDeJong
On the screenshot, I see that the function call "oSheet.PartsLists.Add(oDrawingView, oPlacementPoint1)" in the sub "Partslist()" is getting an invalid argument. That means that the view or the insert point is not valid. I changed your code a bit and added a message box just before the parts list gets added. The message box should tell you the name of the view that is used and the target position. You can try this code when your rule is not working. maybe you will get some more useful information.
Sub Partslist()
    Dim oDrawingDoc As DrawingDocument = ThisApplication.ActiveDocument
    Dim oSheet As Sheet = oDrawingDoc.ActiveSheet
    If (oSheet.PartsLists.Count > 0) Then
        Dim oPartsList As PartsList = oDrawingDoc.ActiveSheet.PartsLists.Item(1)
        oPartsList.Delete()
    Dim oDrawingView As DrawingView = oSheet.DrawingViews(1)
    Dim oBorder As Border = oSheet.Border
    Dim xMax = oBorder.RangeBox.MaxPoint.X
    Dim yMax = oBorder.RangeBox.MaxPoint.Y
    Dim xMin = oBorder.RangeBox.MinPoint.X
    Dim yMin = oBorder.RangeBox.MinPoint.Y
    Dim oPlacementPoint1 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(xMax, yMax)
    MsgBox(oDrawingView.Name & ": " & oPlacementPoint1.X & "," & oPlacementPoint1.Y)
    Dim oPartsList1 As PartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint1)
    Dim PLxrev = (oPartsList1.RangeBox.MaxPoint.X - oPartsList1.RangeBox.MinPoint.X)
    Dim PLyrev = (oPartsList1.RangeBox.MaxPoint.Y - oPartsList1.RangeBox.MinPoint.Y)
    Dim oPlaceX = xMax
    Dim oPlaceY = 0
    Dim PL_Style = Parameter("PL_Style")
    ElseIf PL_Style = "ICM Parts List - Upper Right" Then
        oPlaceY = yMax
    Dim oPlacementPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(oPlaceX, oPlaceY)
    oPartsList1.Renumber()
    oPartsList1.SaveItemOverridesToBOM()
    Dim i As Long
        Dim oCell = oPartList.PartsListRows.Item(i).Item("CUT LENGTH")
        Dim oCell2 = oPartList.PartsListRows.Item(i).Item("CUT_LTH")
            oCell.Value = ""
    Next
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
Brian.Price
Thanks for the tips. I used your code but for some reason it puts the parts list in a different location. The coordinates seem to be the same, not sure why it does that. Anyways I ran into the same issue while using your code too.
I later found out that when this happens if I add a balloon it prompts to add a parts list and then the code works again.
Which is weird because I often use this on a fresh drawing that has no parts list and it adds it.
Perhaps there's an issue when it looks for the parts list and finds nothing after a parts list has been removed?
