Constrain subassembly via Workpoint
mk92
mk92
i want to constrain a part in my assembly via workpoints. So i define the Point (Testpoint) in my assembly and the point in my subassembly (StartPoint).
And then i add the constraint. But i doesnt work.
What did i miss?
Regards
Dim wp As WorkPoint
wp = ThisDoc.Document.ComponentDefinition.WorkPoints("Testpoint")
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.Documents.ItemByName(ThisDoc.WorkspacePath()+"\Test.iam")
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAsmDoc.ComponentDefinition
Dim wp2 As WorkPoint
wp2 = oAsmDoc.ComponentDefinition.WorkPoints("StartPoint")
' add the constraint
oAsmCompDef.Constraints.AddMateConstraint(wp, wp2, 0)
MechMachineMan
Geometry Proxies for using work features in a lower level document, I think.
oCylEdge1 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeCircularFilter, "Select the lower most limit of the cylinder bore (Think insert constraint)")
oCylEdge2 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeCircularFilter, "Select the lower most limit of the piston rod (Think insert constraint)")
For Each oWorkPlane In oCylEdge1.Parent.Parent.Definition.Document.ComponentDefinition.WorkPlanes
	oWorkPlane.Visible=True
Next
oCylOrigPlane1 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPlaneFilter, "Select the origin plane of the cylinder")
	oWorkPlane.Visible=False
Next
For Each oWorkPlane In oCylEdge2.Parent.Parent.Definition.Document.ComponentDefinition.WorkPlanes
Next
oCylOrigPlane2 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPlaneFilter, "Select the a co-planar origin plane of the rod")
Next
Dim oCompDef1 As ComponentDefinition = oCylOrigPlane1.Parent()
Dim oCompDef2 As ComponentDefinition = oCylOrigPlane2.Parent()
Dim oCompOcc1 As ComponentOccurrence = oAsmCompDef.Occurrences.AllReferencedOccurrences(oCompDef1).Item(1)
Dim oCompOcc2 As ComponentOccurrence = oAsmCompDef.Occurrences.AllReferencedOccurrences(oCompDef2).Item(1)
oCompOcc1.CreateGeometryProxy(oCylOrigPlane1, oAsmPlane1)
oCompOcc2.CreateGeometryProxy(oCylOrigPlane2, oAsmPlane2)
oMate1 = oAsmCompDef.Constraints.AddMateConstraint(oAsmPlane1, oAsmPlane2, 0)
With oMate1
        .Name = "COINCIDENT PLANE"
        .Offset.Expression = "0 in"
		.Suppressed = False
End With
There is an example of using proxies/making constraints. It was necessary to create the proxies to be able to access the PARTS Origin planes for use in constrains in the top level ASSEMBLY (directly up 1 level from them).
Good luck!
Edit: Looking at my methods, it is kind of convoluted because of the Pick method that I deemed necessary for my process. However, to use the proxies, all you need is the Occurrence containing the workfeatures, and the workfeatures themselves. So it might be easier for you.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
mk92
So if i get it right i need something like this:
Dim oPart2Plane1 As WorkPlaneProxy = Nothing oOcc2.CreateGeometryProxy(oPart2PlaneXZ, oPart2Plane1)
Just customized for my code.
But i dont get the part with the occurences. Can't i use the namens?
MechMachineMan
Check the API and go from there.
Justin K
