Constrain 3d sketch w.r.t workpoints using ilogic
srinivasa_omkaram
srinivasa_omkaram
Im a beginner in creating ilogics. I have an issue that I'm hopeful you all can help with.
I'm trying to write an iLogic to create a 3D sketch using work points. I'm able to create work points at the required coordinates and generate the 3D sketch following those coordinates, but I'm unable to make the sketch dependent on the work points (like using a coincident constraint in between 3d sketch point and workpoint). I need it to be such that if I adjust the work point coordinates, the sketch should update or regenerate automatically (If that is not possible im looking for full dimensional constrains w.r.t origin point).
Sub Main()
    ' Example coordinates (You can replace this with actual points from your model)
    Dim pathCoordinates As New List(Of Point)
    pathCoordinates.Add(ThisApplication.TransientGeometry.CreatePoint(0, 0, 0))
    pathCoordinates.Add(ThisApplication.TransientGeometry.CreatePoint(10, 10, 0))
    pathCoordinates.Add(ThisApplication.TransientGeometry.CreatePoint(20, 20, 20))
    ' Create work points first
    Dim workPoints As List(Of WorkPoint) = CreateWorkPoints(pathCoordinates)
    ' Create the 3D sketch using the work points
    Dim oSketch3D As Sketch3D = Create3DSketchWithWorkPoints(workPoints)
End Sub
' Function to create work points
Function CreateWorkPoints(pathCoordinates As List(Of Point)) As List(Of WorkPoint)
    Dim oPartDoc As PartDocument = ThisDoc.Document
    Dim oCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
    Dim oWPts As WorkPoints = oCompDef.WorkPoints
    Dim workPoints As New List(Of WorkPoint)
    Dim counter As Integer = 1
    For Each point As Point In pathCoordinates
        Dim oWPt As WorkPoint = oWPts.AddFixed(Point)
        oWPt.Name = "WorkPoint" & counter
        workPoints.Add(oWPt)
        counter += 1
    Next
    Return workPoints
End Function
' Function to create a 3D sketch with work points
Function Create3DSketchWithWorkPoints(workPoints As List(Of WorkPoint)) As Sketch3D
    ' Create Sketch3D
    Dim oSk3D As Sketch3D = oCompDef.Sketches3D.Add
    oSk3D.Name = "Sketch3D1"
    ' Edit sketch
    oSk3D.Edit
    ' Create sketch points using work points
    Dim sketchPoints As New List(Of SketchPoint3D)
    For Each oWPt As WorkPoint In workPoints
        ' Create SketchPoint3D using the coordinates of the WorkPoint
        Dim oSkPt As SketchPoint3D = oSk3D.SketchPoints3D.Add(oWPt.Point)
        sketchPoints.Add(oSkPt)
    Next
    ' Create lines connecting the sketch points
    For i As Integer = 0 To sketchPoints.Count - 2
        oSk3D.SketchLines3D.AddByTwoPoints(sketchPoints(i), sketchPoints(i + 1))
    Next
    ' Exit sketch
    oSk3D.ExitEdit
    Return oSk3D
End Function
J-Camper
You are very close.  Just need to connect the point after you create it in the 3D sketch:
oSkPt.ConnectTo(oWPt)
Here is the line added to your code in case it's not clear where to add:
Sub Main()
End Sub
        counter += 1
    Next
    Return workPoints
End Function
    ' Create Sketch3D
    ' Edit sketch
    oSk3D.Edit
    Next
    Next
    ' Exit sketch
    oSk3D.ExitEdit
    Return oSk3D
End Function
