Cone Unfold K Factor
How come when I unfold part of a conical segment that is the same arc length all the way down the part the flat pattern edges are not parallel?  I have the K-Factor set to 1 so the flat pattern should be the same length as the outside edge.  I modeled a short circular segment and it unrolls how I would expect.  How come the flat pattern does not come out to 59.25 and how come the different ends are different widths?
Thanks in advance.
frederic.vandenplas
I guess you are on the wrong forum, please visit https://forums.autodesk.com/t5/inventor-forum/bd-p/78
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
