An unhandled exception of type 'System.Exception' occurred in Microsoft.VisualBa
Hopefully this is easy.  I have the exact same logic elsewhere, no problem.  It is as if the program is not seeing the open instance of Inventor.
Code:
Imports System.IO
Imports System.Runtime.InteropServices
Public Class Form1
    Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
        'TODO: This line of code loads data into the 'Ds_view_partmtl.partmtl' table. You can move, or remove it, as needed.
        Me.PartmtlTableAdapter.Fill(Me.Ds_view_partmtl.partmtl)
    End Sub
    Private Sub cmdRunComp_Click(sender As Object, e As EventArgs) Handles cmdRunComp.Click
        ' Open BOM In Vantage
        ' Open BOM in Inventor
        OpenBOM_Inventor()
    End Sub
    Private Function OpenBOM_Inventor()
        ' Define application
        Dim oApp As Inventor.Application = GetObject(, "Inventor Application")
        Dim oDoc As Inventor.AssemblyDocument = oApp.ActiveDocument
        ' Define Component Definition
        Dim oDocDef As Inventor.AssemblyComponentDefinition = oDoc.ComponentDefinition
        ' Define Leaf Occurrences
        Dim oDocLeaf As Inventor.ComponentOccurrencesEnumerator = oDocDef.Occurrences.AllLeafOccurrences
        ' Iterate through the Leaf Occurrences and print the name
        Dim i As Integer = 0
        Dim oCompOcc As Inventor.ComponentOccurrence = Nothing
        For Each oCompOcc In oDocLeaf
            i += 1
            Debug.Print("Occurrence:" + i + ": " + oCompOcc.Name)
        Next
    End Function
End Class
Pic:
frederic.vandenplas
you need to repliceerde the space with a dot Inventor.Application
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Thanks!
