Component.Visible (iam)
marcin_bargiel
Message 1 of 21
marcin_bargiel
i got subassembly  abc.iam which has three parts :  a:1, b:1, c:1 (one or two of them are always hidden)
when first time i put it to main assembly ---> main.iam,  some part are visible other are hidden - that GREAT !
but then when i need to  set on demand :  visible or not  - abc:1 using below function - all parts are set as visible !
SyntaxEditor Code Snippet
Component.Visible("abc:1")=True
Component.Visible("abc:1")=False
and now a big question : why this function set visibility to all of my parts in "abc:1" not just to only ones which has set visibility   !????
it is at least not understandable behavior ...
i don't want to set visibility or hidden of all parts separately one more time in main.iam !
Vote for REPLACE VARIES !
REPLACE VARIES
Replies (20)
Message 21 of 21
marcin_bargiel
THANK'S A LOT FOR YOUR TIME !  Now works great !!!
In the meanwhile i did workaround, that also is OK.
For Each comp In doc.ComponentDefinition.Occurrences
 comp.Visible = False
 Try
 comp.BOMStructure = BOMStructureEnum.kReferenceBOMStructure
 Catch
 End Try
 comp.Excluded = True
 Next
End If
REPLACE VARIES
