Component Measure
Component Measure
atomic.lex
Component Measure
atomic.lex
Hey,
I'm trying to collect measures of components, but don't know how could it work.
I could ask it in a component
H = Measure.ExtentsHeight
 But couldn't do it for all of components in assembly
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oComps As ComponentOccurrences = oDoc.ComponentDefinition.Occurrences
Dim oComp As ComponentOccurrence
For Each oComp In oComps
H = oComp.Measure.ExtentsHeight
Next
 Any ideas?
Thx, Alex
bradeneuropeArthur
Take  a look at the shortcut in my footer.
is this what you mean?
"Dimension Component!"
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
atomic.lex
Thanks for replay,
as i see, with a little trik  it's not possible. Thats why i wrote a little script, which shows one time only one component and asks assembly measure. Not a simple but usefull way.
Wish you a good day,
Alex
bradeneuropeArthur
I don't understand what you mean.
Please explain further...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
atomic.lex
It looks like:
Dim Hights As New ArrayList()
If Component.IsActive(oComp.Name) = True Then
Component.Visible(oComp.Name) = True
Else
Component.Visible(oComp.Name) = False
Component.IsActive(oComp.Name) = False
Next
H = Round(Measure.ExtentsHeight)
If H > 0 Then Hights.Add(H)
Next
MultiValue.List("Hight") = Hights
If Component.Visible(oComp.Name) = True Then
Else
Next
