code to modify bend precision & symbols to bend-note & link part number with dynamic titles for flat or normal views finally completed.
maxim.teleguz
maxim.teleguz
Have fun making Autodesk better with your tools!
I believe in sharing not selling.
I also believe this unlocks the ability to change hole precision now.
this was a lot of testing and testing as this API is not available for quick understanding.
Imports System
Imports Inventor
Imports System.Runtime.InteropServices
Imports System.Text.RegularExpressions
AddReference "System.Drawing.dll"
AddReference "System.Xml.dll"
' iLogic Rule: Auto‑Ref Flat‑Pattern View (Undoable) with Bend‑Note Precision Edit
Sub Main()
    Dim oApp As Inventor.Application = ThisApplication
    Dim dDoc As DrawingDocument = TryCast(oApp.ActiveDocument, DrawingDocument)
    If dDoc Is Nothing Then
        Logger.Debug("Not a Drawing Document")
        Exit Sub
    ' Start one undoable transaction
    Dim trans As Transaction = oApp.TransactionManager.StartTransaction(dDoc, "Auto‑Ref Flat‑Pattern View")
    Try
        ' Pick a view
        Dim pickView As DrawingView = oApp.CommandManager.Pick( _
            SelectionFilterEnum.kDrawingViewFilter, "Select a View" )
        If pickView Is Nothing Then Exit Sub
        If pickView.IsFlatPatternView Then
            Dim sheet As Sheet = dDoc.ActiveSheet
            ' 1) Reference ALL dims in the picked view except zero‑zero ordinates
            For Each oDim As DrawingDimension In sheet.DrawingDimensions
                If Not oDim.Parent Is pickView Then Continue For
                Dim txt As String = ""
                Try : txt = oDim.Text.Text : Catch : End Try
                If txt.Trim() = "0" _
                   OrElse Regex.IsMatch(txt, "(^|\D)\.[0]+(\D|$)") Then
                    Continue For
                Try : oDim.Tolerance.SetToReference() : Catch : End Try
            Next
            ' 2) Reference & deep‑edit ALL bend notes in the picked view
            For Each dNote As DrawingNote In sheet.DrawingNotes.BendNotes
                Dim bNote As BendNote = CType(dNote, BendNote)
                ' a) Reference the angle callout
                Try
                    CType(bNote.BendAngleDimension, AngularGeneralDimension) _
                Catch : End Try
                ' b) Reference the radius callout
                Try
                    CType(bNote.BendRadiusDimension, RadiusGeneralDimension) _
                Catch : End Try
                ' c) Deep‑edit the bend‑note XML: strip tolerances, force precisions, add parentheses only once
                Try
                    ' — load the current formatted text
                    Dim xmlFrag    As String = bNote.FormattedBendNote
                    Dim trimmedRaw As String = xmlFrag.Trim()
                    ' — if it’s already wrapped in ( ), skip to next note
                    If trimmedRaw.StartsWith("(") AndAlso trimmedRaw.EndsWith(")") Then
                        Continue For
                    ' — load XML into DOM
                    Dim xmlDoc As Object = CreateObject("MSXML2.DOMDocument.6.0")
                    xmlDoc.async = False
                    xmlDoc.loadXML("<root>" & xmlFrag & "</root>")
                    Dim root As Object = xmlDoc.documentElement
                    ' — strip out all tolerance attributes
                    Dim attrList() As String = {
                        "UpperTolerance", "LowerTolerance", _
                        "ToleranceType", "TolerancePrecision", _
                        "ToleranceAlternatePrecision"
                    For Each child As Object In root.ChildNodes
                        If child.nodeType = 1 Then
                            For Each attrName As String In attrList
                                Dim att As Object = child.Attributes.getNamedItem(attrName)
                                If Not att Is Nothing Then child.removeAttribute(attrName)
                            Next
                    Next
                    ' — force Precision on BendAngle → 0
                    Dim angleElem As Object = root.selectSingleNode("//BendAngle")
                    If Not angleElem Is Nothing Then
                        Dim attA As Object = angleElem.Attributes.getNamedItem("Precision")
                        If Not attA Is Nothing Then
                            attA.Text = "0"
                        Else
                            angleElem.setAttribute("Precision", "0")
                    ' — force Precision on BendRadius → 3
                    Dim radiusElem As Object = root.selectSingleNode("//BendRadius")
                    If Not radiusElem Is Nothing Then
                        Dim attR As Object = radiusElem.Attributes.getNamedItem("Precision")
                        If Not attR Is Nothing Then
                            attR.Text = "3"
                        Else
                            radiusElem.setAttribute("Precision", "3")
                    ' — rebuild XML: insert a single space before the Angle & Radius tags
                    Dim newXml As String = ""
                        'If child.nodeName = "BendAngle" OrElse child.nodeName = "BendRadius" Then
                        If child.nodeName = "BendAngle" Then
                            newXml &= " " & child.xml
                        Else
                            newXml &= child.xml
                    Next
                    ' — only wrap in ( ) if it’s not already parenthesized
                    Dim frag As String = newXml.Trim()
                    If Not (frag.StartsWith("(") AndAlso frag.EndsWith(")")) Then
                        newXml = "(" & frag & ")"
                    Else
                        newXml = frag
                    ' — write it back
                    bNote.FormattedBendNote = newXml
                Catch
                    ' if anything fails, skip this note
                End Try
            Next
            ' 3) Override the view label for flat pattern
'            pickView.Label.FormattedText = _
'                "<Property Document='model' " & _
'                  "FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' " & _
'                  "PropertyID='5'>Part Number</Property>" & vbNewLine & _
'                "<StyleOverride Underline='False'>FLAT PATTERN</StyleOverride>"
'			    "<StyleOverride Underline='False'>FLAT PATTERN</StyleOverride>" & vbNewLine & _
'			    "<StyleOverride FontSize='0.2032'>" & _
'			        "PropertyID='5'>Part Number</Property>" & _
'			    "</StyleOverride>"
			    "</StyleOverride>"
        Else
            ' —— Non‑flat pattern: original property‑driven label logic ——
            Dim oPropSet As PropertySet = _
                pickView.ReferencedDocumentDescriptor. _
                    ReferencedDocument.PropertySets(3)
        ' Ensure the label is visible
        pickView.ShowLabel = True
    Finally
        ' End the transaction so all changes become one undo step
        trans.End()
    End Try
End Sub
maxim.teleguz
font size is in CM so convert it as you need it
