MiniToolbarValueEditor. ValueEditor and integers
Ivan_Sinicyn
Ivan_Sinicyn
Hi all,
I'm puzzled. How to properly configure MiniToolbarValueEditor to accept only integers with automatic highlighting of fractional values in red, but without having to create new functions?
I tried writing MiniToolbarValueEditor.Precision Property, but I get an error
Sub Main()
    Dim Inventor As Inventor.Application = ThisApplication
    Dim interactEvents As InteractionEvents
    Dim stillSelecting As Boolean = True
    Dim toolBar As MiniToolbar
    Dim valueEditor As MiniToolbarValueEditor
    interactEvents = inventor.CommandManager.CreateInteractionEvents
    interactEvents.InteractionDisabled = False
    toolBar = interactEvents.CreateMiniToolbar()
    valueEditor = toolBar.Controls.AddValueEditor("MyValueControl", "", ValueUnitsTypeEnum.kLengthUnits, "123")
    valueEditor.MinimumValue = 0.1
    valueEditor.CanValueBeEqualToMinimumValue = True
    AddHandler interactEvents.OnTerminate, Sub()
        stillSelecting = False
    End Sub
    toolBar.ShowApply = False
    toolBar.ShowOptionBox = False
    toolBar.ShowOK = False
    toolBar.Visible = True
    interactEvents.Start()
    Do While stillSelecting
        inventor.UserInterfaceManager.DoEvents()
    Loop
    interactEvents.Stop()
    inventor.CommandManager.StopActiveCommand()
    toolBar.Delete()
End Sub
INV 2025.3
WCrihfield
This is just a quick, educated guess, but maybe when creating the value editor with the MiniToolbarControls.AddValueEditor method, specify unitless type units (ValueUnitsTypeEnum.kUnitless), instead of length type units.  That should help keep all entered values as integers.  Not sure about the highlighting in red part though.  I have used MiniToolbars several times before, but not extensively yet, so have not attempted pushing the limits of their abilities yet.  Probably will before long though. 😉  They are pretty convenient.
Wesley Crihfield
(Not an Autodesk Employee)
Ivan_Sinicyn
@WCrihfield
Thanks for the reply.
ValueUnitsTypeEnum.kUnitless simply allows you to work with dimensionless values and does not restrict or warn in any way when entering fractional numbers.
I've tried dozens of variants, but still can't win. I had to make a handler.
INV 2025.3
