with frame generator in Inventor I can add a gap between two members using the command notch
My request is related to the possibility to recognize the notches in the assembly and force the value to zero (Note:the gap is not a 'standard' parameter)
is it possible to create a Rule in iLogic?
That would grant me the possibility to optain a .iam version without gaps between notches to use for other analysis
Thanks in advance
Diego
