Code not working in 2018
jletcher
Advisor Advisor
Message 1 of 14
jletcher
Looks like some things in ilogic has changed from 2012 to 2018.
without steps in the coding to find the issues I am lost what might have changed.
Here is the code maybe someone already knows and can educate me.
Imports Inventor.ViewOrientationTypeEnum
Imports Inventor.DrawingViewStyleEnum
Dim oDrawDoc as DrawingDocument
Dim oPartDoc as Document
Dim oSheet As sheet
Dim oTG As TransientGeometry
Dim oBaseView As DrawingView
Dim opath As String
opath = ThisDoc.WorkspacePath()
ViewScale = 1/64
'Make Drawing
    oPartDoc = ThisDoc.Document
    'Define IDW Template File Location
	oDrawDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "C:\Users\engineer\Desktop\Inventor 2018 code\625 Temps", False)
    oSheet = oDrawDoc.Sheets.Item(1)
    'Define 2d view bottom left corner points
     oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
	oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint1, 1/64,kFrontViewOrientation, kHiddenLineDrawingViewStyle, "Default")
	oDrawDoc.SaveAs(opath & "\" & "625A1-" & Letter_Code & Mat_Code & L_1 & ".idw" , False)
	oDrawDoc.Close(False)
Replies (13)
Message 2 of 14
bradeneuropeArthur
try this
Scale as Double:
And oPoint1 as Point2d
Dim oSheet As sheet
Dim opath As String
Dim oPoint1 As Point2d opath = ThisDoc.WorkspacePath() Dim ViewScale As Double ViewScale = 1/64 'Make Drawing oPartDoc = ThisDoc.Document 'Define IDW Template File Location oDrawDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "C:\Users\engineer\Desktop\Inventor 2018 code\625 Temps", False) oSheet = oDrawDoc.Sheets.Item(1) 'Define 2d view bottom left corner points oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(0, 0) oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint1, ViewScale,kFrontViewOrientation, kHiddenLineDrawingViewStyle, "Default") oDrawDoc.SaveAs(opath & "\" & "625A1-" & Letter_Code & Mat_Code & L_1 & ".idw" , False) oDrawDoc.Close(False)
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 14
jletcher
No sir still fails
Message 4 of 14
bradeneuropeArthur
I have edit the post.
Opoint1 as point2d
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 14
bradeneuropeArthur
By me it is working now
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 14
bradeneuropeArthur
Please copy the complete code into your project.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 14
jletcher
I did but still fails
Dim oSheet As sheet
Dim opath As String
ViewScale = 1/64
'Make Drawing
Message 8 of 14
bradeneuropeArthur
Is this missing?
For me the code is working.
But I have disabled this line. Because I don't know what those parameters are.
So till this line it is working.
Try also to disable this line. And then check if it is working
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 14
jletcher
The parameter is there but I disabled and tried still fails.
I have 6 rules all work but this one making the drawing.. And that same L_1 is in the part number rule and it makes the part does all right up to making drawing.
I wish I could upload the part but I can't...
I can't get cleared to upload from client...
Message 10 of 14
bradeneuropeArthur
I think I found it.
You define no template idw file
C:\Users\engineer\Desktop\Inventor 2018 code\625 Temps\###.idw
Please check that.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 14
jletcher
Yes you did find it I guess when I copied new path I removed the idw call out...
 Nice catch I look at everything and I kept on missing that wow glad I am going on vacation tonight..
I owe you a beer my  friend..
Message 12 of 14
bradeneuropeArthur
Send it to Europe...... ha ha ha
Nice Holidays and everything else..
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 14
jletcher
Where about in Europe my Uncle is there I will have him buy it LOL...
Message 14 of 14
bradeneuropeArthur
Where is your uncle from?
Maybe we are neighbours!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
