Code for generation of drawing sheet with dimensions from part using ilogics
I created a parametric model using ilogics. Now i need to generate drawing sheet with all views and critical dimensions(only few required dimensions) from part itself without opening a new idw file.I have gone through some codes but i could not do it.
Can anyone show full code for this if that option is available?
Thanks & Regards,
Geetha
martin.jacko
Currently inventor ilogic do not contains simple way how to do it. You have to use API calls for that.
I recommend to create new idea on idea station (if it is not already created).
It sounds like reasonable ilogic requirement.
Martin
Mark.Lancaster
@Anonymous
You will get better results by posting programming needs and questions in the Inventor Customization forum.   I will have the moderator relocate your posting there to better suit your needs.
https://forums.autodesk.com/t5/inventor-customization/bd-p/120
Mark Lancaster
dgreatice
I have that hard code, but I'm sorry its credential.
Tips:
1. Try learn about DrawingCurve (How to identify each drawing curve)
2. Try how to learn create each  dimension with difference type of dimension base on selected drawing view) in each VIEW.
3. Ready for coffee.
Screencast will be displayed here after you click Post.
932d5a8c-0374-4fd9-a859-495f8f75f4f3
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
basnederveen
