Message 1 of 13
11:16 PM
I found this code, but have no experience modifying it. Can you help me to change the code, so it only clears the override on selected parts, and not on all parts in the active assembly?
Many ythanks!
Dim Title As String = "Excitech iLogic" ' Attempt to get the active assembly document Dim oDoc As AssemblyDocument = Nothing Try oDoc = ThisApplication.ActiveEditDocument Catch MessageBox.Show("This rule must be run from an assembly", Title) Exit Sub End Try Dim oADoc As AssemblyDocument = Nothing Dim oPDoc As PartDocument = Nothing Dim TotCount As Integer = oDoc.AllReferencedDocuments.Count Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition Dim oRefDoc As Document = Nothing Dim oPartDef As PartComponentDefinition = Nothing Dim oAsmDef As AssemblyComponentDefinition = Nothing Dim FailCount As Integer = 0 Dim Count As Integer = 1 ' Top level clear override command oDef.ClearAppearanceOverrides() ' Loop through all the documents referenced by this assembly document... For Each oRefDoc In oDoc.AllReferencedDocuments Try ThisApplication.StatusBarText = Count & " of " & TotCount & " components processed." ' Is it a part document? If oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then ' Get the component definition. oPartDef = oRefDoc.ComponentDefinition ' First set the top level part appearance to be the same as the material oRefDoc.AppearanceSourceType = AppearanceSourceTypeEnum.kMaterialAppearance ' Try a top level 'clear appearance overrides' command first oPartDef.ClearAppearanceOverrides() ' Clear the override on all the override objects found.... oPartDef.ClearAppearanceOverrides(ObjColl) ThisApplication.ActiveView.Update() ' Is it an assembly document? ElseIf oRefDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then ' Get the assembly definition oAsmDef = oRefDoc.ComponentDefinition ' Run top level 'clear appearances' command on this assembly ThisApplication.StatusBarText = Count & " of " & TotCount & " components processed. Clearing assembly overrides..." oAsmDef.ClearAppearanceOverrides() End If Count += 1 Catch FailCount += 1 End Try Next ThisApplication.ActiveView.Update() If FailCount > 0 Then MsgBox("All Appearance overrides removed." & vbLf & vbLf & _ "Operation failed on " & FailCount & " component(s) - these may be read-only.", , Title) Else MsgBox("All Appearance overrides removed.", , Title) End If
