Export each views to pdf or png
I'm looking to automatically extract wired views (front, side, top, ISO) where 1 view = 1 file (.pdf/.eps or.png).
These images will be used for technical sheet automatically generated with Adobe Indesign.
Currently, I manually make a drawing that I export to PDF, and extract the views with Adobe Illustrator.
Thank you in advance
HermJan.Otterman
Hello Antoine,
it took me some time but here is som code ...
put it in a iLogic rule and run it in a drawing.
on c:\temp\ will PNG. 's be created...
SyntaxEditor Code Snippet
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
        Dim oDrawView As DrawingView
        Dim oSheet As Sheet
        Dim cam As Camera
        cam = ThisApplication.ActiveView.Camera
        Dim tg As TransientGeometry
        tg = ThisApplication.TransientGeometry
        Dim i As Integer = 0
        For Each oSheet In oDrawDoc.Sheets
            oSheet.Activate()
            For Each oDrawView In oSheet.DrawingViews
                i = i + 1
                cam.Eye = tg.CreatePoint(oDrawView.Center.X, oDrawView.Center.Y, 20)
                cam.Target = tg.CreatePoint(oDrawView.Center.X, oDrawView.Center.Y, 10)
                cam.UpVector = tg.CreateUnitVector(0, 1, 0)
                cam.SetExtents(oDrawView.Width + 1, oDrawView.Height + 1)
                cam.ApplyWithoutTransition()
                ThisApplication.ActiveView.Camera.SaveAsBitmap("C:\temp\picture" & i & ".png", (oDrawView.Width + 1) * 100, (oDrawView.Height + 1) * 100)
            Next
        Next
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Great ! Thank you very much.
It will be so much faster like this.
