Clear appearence override on selected parts
Message 1 of 13
I found this code, but have no experience modifying it. Can you help me to change the code, so it only clears the override on selected parts, and not on all parts in the active assembly?
Many ythanks!
  Dim Title As String = "Excitech iLogic"
        ' Attempt to get the active assembly document
        Dim oDoc As AssemblyDocument = Nothing
        Try
            oDoc = ThisApplication.ActiveEditDocument
        Catch
            MessageBox.Show("This rule must be run from an assembly", Title)
            Exit Sub
        End Try
        Dim oADoc As AssemblyDocument = Nothing
        Dim oPDoc As PartDocument = Nothing
        Dim TotCount As Integer = oDoc.AllReferencedDocuments.Count
        Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
        Dim oRefDoc As Document = Nothing
        Dim oPartDef As PartComponentDefinition = Nothing
        Dim oAsmDef As AssemblyComponentDefinition = Nothing
        Dim FailCount As Integer = 0
        Dim Count As Integer = 1
        ' Top level clear override command
        oDef.ClearAppearanceOverrides()
        ' Loop through all the documents referenced by this assembly document...
        For Each oRefDoc In oDoc.AllReferencedDocuments
            Try
                ThisApplication.StatusBarText = Count & " of " & TotCount & " components processed."
                ' Is it a part document?
                If oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
                    ' Get the component definition.
                    oPartDef = oRefDoc.ComponentDefinition
                    ' First set the top level part appearance to be the same as the material
                    oRefDoc.AppearanceSourceType = AppearanceSourceTypeEnum.kMaterialAppearance
                    ' Try a top level 'clear appearance overrides' command first
                    oPartDef.ClearAppearanceOverrides()
                    ' Clear the override on all the override objects found....
                    oPartDef.ClearAppearanceOverrides(ObjColl)
                    ThisApplication.ActiveView.Update()
                    ' Is it an assembly document?
                ElseIf oRefDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
                    ' Get the assembly definition
                    oAsmDef = oRefDoc.ComponentDefinition
                    ' Run top level 'clear appearances' command on this assembly
                    ThisApplication.StatusBarText = Count & " of " & TotCount & " components processed. Clearing assembly overrides..."
                    oAsmDef.ClearAppearanceOverrides()
                End If
                Count += 1
            Catch
                FailCount += 1
            End Try
        Next
        If FailCount > 0 Then
            MsgBox("All Appearance overrides removed." & vbLf & vbLf & _
        "Operation failed on " & FailCount & " component(s) - these may be read-only.", , Title)
        Else
            MsgBox("All Appearance overrides removed.", , Title)
        End If
Replies (12)
Message 2 of 13
HermJan.Otterman
Hello jdg,
Try first to select your parts than run this:
        Try
        Catch
            Exit Sub
        End Try
        Dim oObj As Object = Nothing
        Dim SelectedOccurences As ObjectCollection
        SelectedOccurences = ThisApplication.TransientObjects.CreateObjectCollection
        For Each oObj In oDoc.SelectSet
            Try
                If oObj.Definition.Document.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Or
                    oObj.Definition.Document.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
                    SelectedOccurences.Add(oObj)
                End If
            Catch ex As Exception
            End Try
        Next
        oDef.ClearAppearanceOverrides(SelectedOccurences)
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Message 3 of 13
Many Thanks! That is indeed my preferred workflow: Select the parts, than run the rule, but this one doesn't change anything. Does it on your side?
Message 4 of 13
HermJan.Otterman
Hi, Yes for me it does change things.
I made a screencast where you can see that it will change.
the designview is what is being changed! so if you have a sub assy an you open it, it can look defferent than when you look at it from the main assembly... so this is why you sometime don't see changes...
Herm Jan
Message 5 of 13
HermJan.Otterman
Herm Jan
Message 6 of 13
Appreciate your help. Here is mine
https://autode.sk/2JTh05S
Message 7 of 13
HermJan.Otterman
Hello Johan,
Can you share your Assembly, shown in the screen cast, then I will look in to that.
Herm Jan
Message 8 of 13
zipped pack and go
Message 9 of 13
HermJan.Otterman
dear Johan,
I added and altered some of the code I deleted,
on you assembly this now works.
maybe test it with sub assies...
the code:
        Try
        Catch
            Exit Sub
        End Try
            Try
                End If
            End Try
        Next
        'Loop through all the documents referenced by this assembly document...
        For Each oObj In SelectedOccurences
            Try
                    'ThisApplication
                    If oObj.Definition.Document.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
                        oObj.Definition.Document.AppearanceSourceType = AppearanceSourceTypeEnum.kMaterialAppearance
                        oObj.Definition.ClearAppearanceOverrides()
                        '' Clear the override on all the override objects found....
                        'oObj.Definition.ClearAppearanceOverrides(oObj)
                        'ThisApplication
                    ElseIf oObj.Definition.Document.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
                        oAsmDef = oObj.Definition
                        'ThisApplication
                        'oAsmDef.ClearAppearanceOverrides(oObj)
                    End If
                    Count += 1
                End If
            Catch
                FailCount += 1
            End Try
        Next
        'ThisApplication
        Else
        End If
    End Sub
Herm Jan
Message 10 of 13
Thank you, but if i try to save the rule I get error
Error on Line 98 : End Sub moet worden voorafgegaan door een overeenkomende Sub-instructie.
Message 11 of 13
HermJan.Otterman
delete the last line: "end sub"
Herm Jan
Message 12 of 13
Thank you very much! Works like a charm.
Was my assembly that other than yours that it didn(t work in the 1st place?
Message 13 of 13
HermJan.Otterman
yours had overides in the parts, I tested with overrides in the assembly..
Herm Jan
