Class Modules + 'Custom Event Triggers'
MechMachineMan
Advisor Advisor
MechMachineMan
Hi there, hoping some help with some more programmeresq stuff.
I'm currently reading a book on excel vba and it goes over how you can create custom event handling for the application by using a class module and initializing that within a module, so I'm trying that here, but its giving me an error.
Here is what I have put in for code so far:
Class Module Named clsAppEvents:
Public WithEvents invApp As Inventor
Private Sub invApp_OnSaveDocument(ByVal DocumentObject As Document, ByVal BeforeOrAfter As EventTimingEnum, ByVal Context As NameValueMap, HandlingCode As HandlingCodeEnum)
    MsgBox ("Document Was Saved!")
End Sub
Module named EventModule:
Public myAppEvent As New clsAppEvents
Sub TrapAppEvent()
    Set myAppEvent.invApp = ThisApplication
End Sub
However, trying to run the trap events macro causes a:
Comple Error: Object does not source automation events.
Is there any way to make this sort of thing work in inventor?
Ideally I want to avoid creating a full macro, but be able to use my vba project to program in a check on file save to remind the user to update a spreadsheet we have.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Might it be easier to use iLogic and set the trigger to on save?
MechMachineMan
Definitely would be easier. But then you miss out on a world of
opportunities and functionality.
Justin K
Jef_E
I use this in visual studio, hope it helps!
' Application Events object.
Private m_AppEvents As ApplicationEvents
Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
       ' This method is called by Inventor when it loads the AddIn.
       ' The AddInSiteObject provides access to the Inventor Application object.
       ' The FirstTime flag indicates if the AddIn is loaded for the first time.
       ' Initialize AddIn members.
       m_inventorApplication = addInSiteObject.Application
       ' TODO:  Add ApplicationAddInServer.Activate implementation.
       ' e.g. event initialization, command creation etc.
       oAppEvents = m_inventorApplication.ApplicationEvents
End Sub
Private Sub OnActivateDocument(ByVal DocumentObject As Inventor._Document,
                               ByVal BeforeOrAfter As Inventor.EventTimingEnum,
                               ByVal Context As Inventor.NameValueMap,
                               ByRef HandlingCode As Inventor.HandlingCodeEnum) _
                               Handles oAppEvents.OnActivateDocument
       ' Check if the timining is after the document is activated.
       If BeforeOrAfter = EventTimingEnum.kAfter Then
           DDC.GetCurrentDocumentDescription()
End Sub
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
SometimesInventorMakesMeAngry
I believe you should replace
with
Set myAppEvent.invApp = ThisApplication.ApplicationEvents
 I know it's been years since this was posted, but maybe it'll help someone searching for this.
you need to initialize your class
Dim WithEvents oAppEvents As ApplicationEvents
Private Sub Class_Initialize()
    Dim invapp As Inventor.Application
    set invapp = ThisApplication
    Set oAppEvents = invapp.ApplicationEvents
End Sub
Private Sub oAppEvents_OnSaveDocument(DocumentObject As Document, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum)
    If BeforeOrAfter = kBefore Then
        MsgBox "your are about to save " & DocumentObject.DisplayName & " !!!"
    HandlingCode = kEventNotHandled 'tell Inventor to handle the events like it usually does
End Sub
After that, you simply need to generate an instance of your class module for the event to subscribe
