Circular holes - Tubes
iva.btblan
Message 1 of 11
iva.btblan
I always have to keep counting holes.
Several studies are conducted until you reach the final result.
The holes vary according to the studies.
I have to keep counting holes over and over again.
Is it possible to create a rule to count these holes?
Has a rule in the file.
Replies (10)
Message 2 of 11
A.Acheson
Hi @iva.btblan .
I wasn't able to open your file to investigate your rule. If possible it is best to post the rule in the forum post this way you can get some immediate help outside of looking at the files themselves.
Here is one such approach to count holes. The API helps samples are good resources for this analysis work. This help page has lot of the information all ready laid out.
The rule  works by identifying cylinder shaped faces which is a component of a hole. Then checking the radius of this face in order to identify the hole being counted. You can use a highlight set as a tool to identify objects so you know what objects you have found.
	'Set the part document variables.
	Dim PartDoc As PartDocument = ThisDoc.Document
	Dim CompDef As PartComponentDefinition = PartDoc.ComponentDefinition
	'Create a list for storing objects
	Dim HoleFaces As New List(Of Face)
	'Create a highlight Set.
	Dim Set1 As HighlightSet = PartDoc.CreateHighlightSet
	'Loop through all faces.
	For Each PartFace As Face In CompDef.SurfaceBodies.Item(1).Faces
		If PartFace.SurfaceType = SurfaceTypeEnum.kCylinderSurface Then
			'Get the Cylinder mathematical Object.
		    Dim Cyl As Cylinder = PartFace.Geometry
			'Get the Cylinder radius.
		    Dim CylRadius As Double = Cyl.Radius
			'Logger.Info("CylRadius :" & CylRadius)
			'Filter radius, measurements in system units cm.
			If CylRadius = 0.5 Then
				Set1.AddItem(PartFace)
				HoleFaces.Add(PartFace)
	Next
	'Change the color of the highlight set to green.
	 Set1.Color = ThisApplication.TransientObjects.CreateColor(0, 255, 0)
	 MessageBox.Show(HoleFaces.Count, "Hole Count")
And another approach is to look into the hole patterns and identify the parameters used for hole qty. This approach is a little more difficult as you need to know how the part is constructed which can be time consuming.
	Dim RecPatCount As Integer
	Dim RecPatSpacing As Double
	Dim CircPatCount As Integer
	Dim CircPatAngle As Double
	For Each Feat As PartFeature In CompDef.Features
		If Feat.Type = ObjectTypeEnum.kRectangularPatternFeatureObject Then
			RecPatSpacing = Feat.Parameters.Item(1).Value
			RecPatCount = Feat.Parameters.Item(2).Value
			Logger.Info("RectangularPatternFeature-Spacing: " & RecPatSpacing)
			Logger.Info("RectangularPatternFeature-RowCount: " & RecPatCount)
			Set1.AddItem(Feat)
		ElseIf Feat.Type = ObjectTypeEnum.kCircularPatternFeatureObject
			CircPatAngle = Feat.Parameters.Item(1).Value
			CircPatCount = Feat.Parameters.Item(2).Value
			Logger.Info("CircularPatternFeature-AngularSpacing in Radians: " & CircPatAngle)
			Logger.Info("CircularPatternFeature-RowCount: " & CircPatCount)
			Set1.AddItem(Feat)
	Next
	Dim HoleCount As Integer = RecPatCount * CircPatCount
	 MessageBox.Show(HoleCount, "HoleCount")
Regards
Alan
Message 3 of 11
iva.btblan
Thank you for your attention.
Is it possible to include the holes below?
03.05.0002.pngBottom holes of 12 holes. Total holes 66.
Message 4 of 11
A.Acheson
It looks like you use the pattern detection code. If this has failed you have it modeled different than I have. It would be better to use the faces count code and set up your radius filter to be between a normal range of holes you expect. All you want to do is filter out the tube itself as being a hole as it is still a cylinder.
If CylRadius > 0.1 And CylRadius < 1 Then
Regards
Alan
Message 5 of 11
iva.btblan
I couldn't understand where I should put this line below.
Can you help by explaining where should I put this sentence to work the rule?
Iva
Message 6 of 11
A.Acheson
That line will simply be the criteria for selecting the correct cylinder shape.
Here is the update code with criteria changed. You will need to change the criteria (hole radius) to what works in your case.
	Next
Regards
Alan
Message 7 of 11
_dscholtes_
The cylindrical face of the unperforated tube is bounded by two edgeloops (top and bottom). The same goes for every cylindrical hole made in the tube (edge on inside and outside of tube). So the perforated tube can easily be found, because it is the only cylindrical face with more than two edgeloops. So by getting the edgeloops count and substracting two from this amount, you have the total amount of holes in the tube. No matter how the perforated tube was made.
Message 8 of 11
A.Acheson
As kindly recommended by @_dscholtes_   Edge loops can be used. So this will look at the faces of the part and count the top of the hole and the tube cylinder ends. The untested code below will find both the inner and outer tube faces but as they will have the same count number either or is acceptable.
          If PartFace.EdgeLoops.Count>2 Then
            Dim Count as Integer = PartFace.EdgeLoops.Count -2
	Next
	 MessageBox.Show(Count, "Hole Count")
Regards
Alan
Message 9 of 11
iva.btblan
Thanks for the answer.
I understand perfectly. It will be necessary to add a cap to this tube.
The lid will have several holes.
Message 10 of 11
A.Acheson
I think the added end cap would be best counted using the faces and filtering the cylinder radius.  This avoids the need to calculate the edge loops. Can you share the attempted code? I think there is enough methods mentioned to attempt your additional features hole count.
Regards
Alan
Message 11 of 11
A.Acheson
The easiest I have found is still the check faces and check for cylinder shape of known radius.
			'Logger.Info("oCylinderRadius :"& CylRadius)
			If CylRadius > 0.01 AndAlso CylRadius < 2 Then
	Next
Regards
Alan
