Amount Holes 2D. In Rows.
iva.btblan
iva.btblan
After the completion of the study.
I need to indicate the amounts of holes in the 2d.
This indication is necessary to facilitate manufacturing. it's tiring to count all these holes.
JelteDeJong
try this:
Public Class ThisRule
    Sub Main()
        Dim doc As DrawingDocument = ThisDoc.Document
        Dim sheet As Sheet = doc.ActiveSheet
        Dim view As DrawingView = sheet.DrawingViews.Item(1)
        Dim rows As New List(Of Row)
        For Each curve As DrawingCurve In view.DrawingCurves
            If (curve.CurveType = CurveTypeEnum.kCircleCurve) Then
                Dim center = curve.CenterPoint
                Dim x = center.X
                Dim y = center.Y
                Dim foundRow = rows.Where(Function(r) Math.Abs(r.Y - y) < 0.0001).FirstOrDefault
                If (foundRow Is Nothing) Then
                    Dim row As New Row(curve)
                    rows.Add(row)
                Else
                    foundRow.N += 1
                    If (foundRow.X > x) Then
                        foundRow.HoleCUrve = curve
        Next
        Dim orderdRow = rows.OrderBy(Function(r) r.Y)
        Dim lineSpacing = 0.75
        Dim insertPointX = view.Center.X - view.Width / 2 - 1.5
        Dim insertPointY = view.Center.Y - (lineSpacing * orderdRow.Count / 2)
        For Each row As Row In orderdRow
            logger.Info(Row.N)
            Dim leaderPoints = ThisApplication.TransientObjects.CreateObjectCollection()
            Dim insertPoint = ThisApplication.TransientGeometry.CreatePoint2d(insertPointX, insertPointY)
            Dim curveIntent As GeometryIntent = sheet.CreateGeometryIntent(Row.HoleCUrve)
            leaderPoints.Add(insertPoint)
            leaderPoints.Add(curveIntent)
            sheet.DrawingNotes.LeaderNotes.Add(leaderPoints, String.Format("{0} Holes", Row.N))
            insertPointY = insertPointY + lineSpacing
        Next
    End Sub
End Class
Public Class Row
    Public Sub New(holeCUrve As DrawingCurve)
        Me.HoleCUrve = holeCUrve
        N = 1
        Y = holeCUrve.CenterPoint.Y
    End Sub
    Public Property HoleCUrve As DrawingCurve
    Public Property N As Integer
    Public Property Y As Double
    Public ReadOnly Property X As Double
        Get
            Return HoleCUrve.CenterPoint.X
        End Get
    End Property
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
iva.btblan
Wonderful!
thank you for your attention.
Thanks for the help!
