Holes Ilogic - Quantity - Variation.
iva.btblan
iva.btblan
Conducting studies.
The dimensions change until you reach the final result. For this it has many variations.
After the changes in the amount of holes.
It is not updated.
Is it possible to reverse this process?
Update the amount of holes?
Ilogic suppressed everything. ilogic does not reverse the process.
06.05.0006.png06.05.0007.png06.05.0009.png06.05.0010.pngI can't handle this. can someone help me.
iva.btblan
Please,
Can anyone help to solve this problem?
JelteDeJong
try this:
Dim doc As PartDocument = ThisDoc.Document
Dim pattern As RectangularPatternFeature = doc.ComponentDefinition.Features.RectangularPatternFeatures.Item(1)
Dim dia As Double = d0 / 10
Dim borderOffset = d17 / 10
Dim hole As HoleFeature = pattern.Definition.ParentFeatures.Item(1)
Dim holeDia As Double = hole.HoleDiameter.Value
Dim radius2 = ((dia - holeDia) / 2 - borderOffset) ^ 2
Dim firstElement = pattern.PatternElements.Item(1)
Dim centerPos As Vector = firstElement.Transform.Translation
Dim X = centerPos.X
Dim Y = centerPos.Y
Dim Z = centerPos.Z
For Each item As FeaturePatternElement In pattern.PatternElements
    If (item Is firstElement) Then Continue For
    item.Suppressed = True
    Try
        Dim ev = item.Transform.Translation
        Dim diffX = (X - ev.X) ^ 2
        Dim diffY = (Y - ev.Y) ^ 2
        Dim diffZ = (Z - ev.Z) ^ 2
        Dim itemRadius = diffX + diffY + diffZ
        If (radius2 > itemRadius) Then
            item.Suppressed = False
    Catch ex As Exception
    End Try
Next
doc.Update()
Jelte de Jong
Blog: hjalte.nl - github.com
iva.btblan
Wonderful!
Thank you so much for your help.
iva.btblan
