Chooser. Macros
Chooser. Macros
Chooser. Macros
Is there some way of telling what macro you are opening, which is to
say, is there another way of loading macros other then the
Tools/Macro/Macros... All I can currently see is the first couple of
directories and if the directories are all the same, it makes it
difficult to pick out the correct one.
Chose all applications and active documents at the top of the pull down
curtain. It will give you all the macros available.
Ole
"Charles Bliss" wrote in message
news:3BF64B99.218B0FB5@cbliss.com...
I agree .... the tools to run macro's are way to cumbersome right now. I trust that
this will change in time but currently I find I don't use Macro's as much as I would
normally just because they are so cumbersome to get to and run.
The only suggestion I have is to keep the IDE open and find the macro in the project
explorer or simply change the dropdown macro list to show All macro's
Kent Keller
http://kwik-mcad.scriptmania.com/
