Selecting Revisited
Selecting Revisited
Message 1 of 9
Selecting Revisited
I am still having a hard time getting my head around the selection methods.
I have taken the clsSelect from the Isolate_Constrained_Parts_V01 that Brian posted.
I have a form that when I choose the select button, I hide that form, and bring up a
much smaller form that has a done button.
In the clsSelect Class module, I removed the OnSelect sub, and added a Public sub
that is called when a button on my small form is pressed. All this sub does is set
bStillSelecting to False.
That much appears to work OK, but
I have made a Public OselectSet and call it from the above form Select Button as
such
Set oSelectset = oSelect.Pick(15884)
When the selection rountine is finished I check oSelectset and it always shows it
as being nothing.
Is it because I am brining up the second form or what am I doing wrong.
Kent Keller
http://kwik-mcad.scriptmania.com/
Replies (8)
Message 2 of 9
I think this area has the possiblity of causing Insanity!
I have canned all projects requiring numbers to be returned.
One could only guess at why it is more complex than anything else!
Cheers for the Suppressor as well!
Simon
Message 3 of 9
Kent,
I'm a little confused on what your trying to select. Are you trying to select a face and list that face? Or just selecting items in general? By the way you or anyone else going to AU? Mike@RTSWright.
Message 4 of 9
Hi Mike
I explained it that badly huh 8^)
I am actually trying to make a selection set of Features. But at other points in the
program I want to make a selection set of other things. Once I get the selection
set I want to change some properties on them.
No AU for me this year. Business has slowed way down, so I didn't even ask. 8^/
Kent Keller
"MDB" wrote in message
news:f098b61.1@WebX.maYIadrTaRb...
> Kent,
Message 5 of 9
Mike or anyone willing to help 8^)
I have placed a ivb file in customer files that might show a little better what I
am attempting to do.
bring up a part drawing. Run or step thru the program, and choose the select
button. Select a couple of part features, and then select the End Selection button
(I am also interested in a cleaner method of ending the selection) Anyhow at that
point I would like my oSelect selection set to contain the Features so I can
manipulate them. The way I am trying it always comes back with a error that
oSelect variable is not set.
Kent Keller
> Kent,
Message 6 of 9
Kent,
The main problem is that the clsSelect Pick function returns a single Object
and this is probably not what you want.
I've changed the code (posted under the original message) to return a
Collection of the selected features and combined the Select and Done button
to one instead of two.
Hope this will bring you a step further.
PS. did Brian really post the Isolate_Constrained_Parts_V01 example? maybe
some of my earlier statements are true anyway!!
-Patrick
Message 7 of 9
Sorry Patrick Did I get yours and Brians Mixed up? I know both of you posted
versions and at the time I was to busy, so I put them away to look at later. Sounds
like I got the two mixed up somehow. Sorry. I feel like I have had 15 projects
half done for so long now, that I am getting all of them mixed up.
Guess that just goes to prove that I am a airhead .8^)
Off to grab your post .... Thanks....hoping I can get a little closer to finishing
up a project. 8^)
Kent Keller
"Patrick de Stobbeleir" wrote in message
news:23476B63949504FD698E5D21E67643B0@in.WebX.maYIadrTaRb...
> Kent,
> -Patrick
Message 8 of 9
Kent, you are welcome to ask again if you have some more problems and I'll
try to solve them.
PS. I would never consider you as a airhead, I know how things are in the
rush hours.
"Kent Keller" wrote in message
news:ABCBE8FC6E104F20D50ADE454A797AC2@in.WebX.maYIadrTaRb...
posted
later. Sounds
projects
finishing
| up a project. 8^)
| Kent Keller
| > Kent,
Object
button
maybe
| > -Patrick
Message 9 of 9
Patrick
Thanks It works like a charm. 8^)
Now I wish I fully understood it all 8^/
Kent Keller
http://kwikmcad.topcities.com/
