- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I recently found out that within a multivalue list you can also use formulas instead of only a numeric value. I used this for a couple of parameters and an example of one of my multivalue lists is:
0 mm
0,5 mm
Breedte_Regel_L1_Helft
Breedte_Regel_L1_Helft + 0,5 mm
-Breedte_Regel_L1_Helft
(Breedte_Regel_L1_Helft being another parameter)
This seems to work perfectly when I choose the values manually, but I'd like to set some of these using iLogic. When I try to set the parameter value as 0 mm or 0,5 mm, this works perfectly, but I'm struggling to set it to one of the formula's. If I type in the formula, the value itsself is correct, but it's not a formula anymore. If I type in the formula between "" I get an error because it can't seem to deal with strings.
Is there some way to do this easily?
