iLogic - distinguish if assembly saved a file or I manually did it
david.kirschner07
david.kirschner07
I would need your advice in the following issue:
I remind a user with a Yes/No MsgBox not to forget to edit the iProperties, because it is often a missed step. I trigger this rule "Before save the document", but the problem occurs when I have an assembly with lots of parts. Then the saving triggers the iLogic and I have to click on the button every time a part is saved.
Is there a way to distinguish somehow in iLogic if the part is saved by the user or by an assembly?
Then i would include an "if statement"  before I prompt the user.
Here is the basic code:
'Reminder to edit the iProperties
Dim buttonValue As Integer
buttonValue = MessageBox.Show("Don't forget to fill out the iProperties! Would you like to do it now?", "Reminder" ,MessageBoxButtons.YesNo)
	' yes is 6, no is 7
If buttonValue = 6 Then
	Call OpeniProperties
Thanks for your help in advance!
JelteDeJong
you could try this before the code you already have.
Dim activeDocName As String = ThisApplication.ActiveDocument.FullFileName
Dim thisDocName As string = ThisDoc.Document.FullFileName
If (activeDocName <> thisDocName) Then
    ' the script was not trigerd by the active document
    Return
Jelte de Jong
Blog: hjalte.nl - github.com
david.kirschner07
Thank you very much for the quick reply, it was a super idea!
