Checking PDF's into the Vault with iLogic
youann21700
youann21700
Currently I have a drawing revision system in place that creates a PDF of drawings once they are approved along with the idw file. Both of these files are locked and saved in an ISSUED folder. I have been able to save the idw files into the vault with iLogic but am struggling to do the same for the exported PDF files. Ideally both of the files would be saved in saved locally as read-only and then checked into the Vault.
Does anyone have a method of checking non-inventor files into the vault?
youann21700
Solved! heres a link to the solution, https://forums.autodesk.com/t5/inventor-programming-ilogic/upload-pdf-file-to-vault-basic-with-ilogi...
heres the code as well:
'CODE BY EUAN YOUR WELCOME
'THIS STARTS A TRANSACTION, WHATEVER THAT IS, THEY CAN TRACK CHANGES TO A DOCUMENT, THEREFORE CAN BE REVERSED
Sub Main()
	Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(ThisApplication.ActiveDocument, "Export and Attach PDF file")
	Try
		If Not ThisApplication.ActiveDocument.FullFilename = String.Empty Then 'won't run if the active document isn't saved.
			Dim filenameToAttach As String = ExportToPDF()
			If Not filenameToAttach = String.Empty Then
				Dim doc As Document = ThisApplication.ActiveDocument
				AddReferences(doc, filenameToAttach)
			End If
		Else
			MessageBox.Show("File not saved; save the file and try again!")
			trans.Abort()
		End If
		trans.End()
	Catch
		trans.Abort()
	End Try
End Sub
'MAIN FUNCTION, EXPORTS A PDF FILE OF THE DRAWING, REMOVES LINE WEIGHTS, MAKES READ ONLY (ITS AN ISSUED DRAWING SO READ ONLY IS NEEDED)
Function ExportToPDF() As String
	Dim filename As String
	' Get the PDF translator Add-In, that is the long string, others for other file formats are online somewhere.
	Dim oPDFTranslator As TranslatorAddIn
	oPDFTranslator = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	Dim oContext As TranslationContext
	oContext = ThisApplication.TransientObjects.CreateTranslationContext
	Dim oOptions As NameValueMap
	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	If oPDFTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
		oOptions.Value("Remove_Line_Weights") = 1
		oOptions.Value("Sheet_Range") = kPrintAllSheets
	    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	    Dim oData As DataMedium
	    oData = ThisApplication.TransientObjects.CreateDataMedium
		oData.FileName = ThisDoc.Path & "\Issued\" & ThisDoc.FileName(False) & " REV " & iProperties.Value("Project", "Revision Number") & " " & iProperties.Value("Custom", "ReleaseStatus") & " .pdf"
		checkpath = ThisDoc.Path & "\Issued"
		Dim oFolder As String = checkpath
		If Not System.IO.Directory.Exists(oFolder) Then
		System.IO.Directory.CreateDirectory(oFolder)
		End If
		oPDFTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData)
		filename = oData.FileName
		Dim oFile As System.IO.FileInfo
		oFile = New System.IO.FileInfo(filename)
		oFile.IsReadOnly = True
	End If
	If System.IO.File.Exists(filename) Then
		Return filename
	Else
		Return ""
	End If
End Function
'THIS PART MAKES THE PDF A REFERENCED DOCUMENT IN THE DRAWING, MEANS WILL BE CHECKED IN/OUT WITH THE DRAWING, this solves the issue of that initial check-in
Public Sub AddReferences(ByVal odoc As Inventor.Document, ByVal selectedfile As String)
	Dim oleReference As ReferencedOLEFileDescriptor
	If selectedfile.Contains("|") Then ' we have multiple files selected.
		Dim file As String() = selectedfile.Split("|")
		For Each s As String In file
			oleReference = odoc.ReferencedOLEFileDescriptors _
				.Add(s, OLEDocumentTypeEnum.kOLEDocumentLinkObject)
			oleReference.BrowserVisible = True
			oleReference.Visible = False
			oleReference.DisplayName = Mid$(s, InStrRev(s, "\") + 1)
		Next
	Else
				.Add(selectedfile,OLEDocumentTypeEnum.kOLEDocumentLinkObject)
		oleReference.DisplayName = Mid$(selectedfile, InStrRev(selectedfile, "\") + 1)
	End If
End Sub
