Add Occurence - Resolve File
gopinathmY575P
gopinathmY575P
Hello Community,
I'm adding component in the assembly using vba Set oOcc1 = oAsmCompDef.Occurrences.Add(filePath, oMatrix), but it throws resolve file message. i need to skip/resolve this message/error automatically at the backend through vba. I'm attaching error image.
FINET_Laurent
Hello @gopinathmY575P,
You could mabye try to set the Inventor.Application property SilentOperation, like this :
ThisApplication.SilentOperation = True
' ... do your code stuff ...
ThisApplication.SilentOperation = False
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
