iLogic - Select two lines and arrowheads are joined together
Viktor.Lukjanow
Viktor.Lukjanow
is it possible to write an iLogic that does the following for me. Select two lines and arrowheads are joined together.
step 1
then
I would be very thankful for a solution
Viktor.Lukjanow
I think there is a Solution like this Code:
Dim oTg = ThisApplication.TransientGeometry
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.ActiveSheet
Dim dimension = ThisApplication.CommandManager.Pick(
	SelectionFilterEnum.kDrawingDimensionFilter,
	"Select a VERICAL dimension")
Dim rows As FeatureControlFrameRows = sheet.FeatureControlFrames.CreateFeatureControlFrameRows()
rows.Add(GeometricCharacteristicEnum.kPosition, "Ø0.015", "", "A",)
Dim pointCollection = ThisApplication.TransientObjects.CreateObjectCollection()
Dim textPoint = dimension.Text.Origin
' move the FeatureControlFrame away from the text.
Dim position As Point2d = oTg.CreatePoint2d(
    textPoint.X + 1.0,
    textPoint.Y +4.0)
pointCollection.Add(position)
' Add the Next 2 lines if you want a leader
'Dim intent = sheet.CreateGeometryIntent(dimension, dimension.DimensionLine.MidPoint)
Dim intent = sheet.CreateGeometryIntent(dimension, dimension.DimensionLine.StartPoint)
'Dim intent = sheet.CreateGeometryIntent(dimension, dimension.DimensionLine.EndPoint)
pointCollection.Add(intent)
Dim fcf = sheet.FeatureControlFrames.Add(pointCollection, rows)
fcf.Rotation = (Math.PI / 180) * 90
But here I create a FeatureControlFrames. And set it to an end point or a start point.
And now I need a Pick Selection to select two lines and intent them together.
Any idea?
JelteDeJong
Run this rule. Then select a frame and a dimension.
Dim frame As FeatureControlFrame = ThisApplication.CommandManager.Pick(
	SelectionFilterEnum.kDrawingFeatureControlFrameFilter,
	"Feature control frame ")
Dim dimension As DrawingDimension = ThisApplication.CommandManager.Pick(
	"Select Dimension")
Dim node As LeaderNode = frame.Leader.AllLeafNodes.Item(1)
Dim segment As LineSegment2d = dimension.DimensionLine
Dim diff1 = Math.Abs(segment.StartPoint.X - node.Position.X) ^ 2 + Math.Abs(segment.StartPoint.Y - node.Position.Y) ^ 2
Dim diff2 = Math.Abs(segment.EndPoint.X - node.Position.X) ^ 2 + Math.Abs(segment.EndPoint.Y - node.Position.Y) ^ 2
If (diff1 < diff2) Then
	node.Position = segment.StartPoint
Else
	node.Position = segment.EndPoint
Dim intent = sheet.CreateGeometryIntent(dimension, node.Position)
node.AttachedEntity = intent
Jelte de Jong
Blog: hjalte.nl - github.com
Viktor.Lukjanow
Amazing - THX - JelteDeJong
