Checking in/out non-Inventor files in Vault via iLogic
Daan_M
Daan_M
I currently have a code that writes data to an Excel file which is saved in Vault, this works fine, but i would like to check-in the Excel file in Vault at the end.
I see snippets to check-in/check-out active documents such as an assembly (Tested and this works great). But this doesn't work for the Excel file, since it's not an 'active document'.
Is it possible what i'm asking or is there no solution currently?
daltonNYAW9
You can use the .addfile method.
iLogicVault.AddFile(fullfilename, vaultfolderpath)
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=33786554-75a9-06db-a868-b42f2883a355
daltonNYAW9
Heres how you would check a file back in using the vault api
Use this link for examples/documentation working with vault programmatically :
https://forums.autodesk.com/t5/inventor-programming-ilogic/vault-api-reference/td-p/11820257
AddReference "Autodesk.Connectivity.WebServices.dll"
Imports ACW = Autodesk.Connectivity.WebServices
AddReference "Autodesk.DataManagement.Client.Framework.Vault.dll"
Imports VDF = Autodesk.DataManagement.Client.Framework
AddReference "Connectivity.Application.VaultBase.dll"
Imports VB = Connectivity.Application.VaultBase
AddReference "Autodesk.DataManagement.Client.Framework.Vault.Forms.dll"
mVltCon = VB.ConnectionManager.Instance.Connection
Dim filepath() As String = {"$/Designs/test.xlsx" }
Dim wsFiles() As ACW.File = mVltCon.WebServiceManager.DocumentService.FindLatestFilesByPaths(filepath)
Dim mFileIt As VDF.Vault.Currency.Entities.FileIteration = New VDF.Vault.Currency.Entities.FileIteration(oVaultConnection, wsFiles(0))
If mFileIt.IsCheckedOut = True
	mVltCon.FileManager.CheckinFile(mFileIt, "", False, New ACW.FileAssocParam() {}, Nothing, False, Nothing, ACW.FileClassification.None, False)
