Rotate a flat
Rotate a flat
kv5053545
Rotate a flat
kv5053545
Hi, I am working with a part that is a flat and I am trying to rotate it if the height is greater than the width, I have a code started but I do not know how to access the rotation property to rotate the flat, have you done something similar, do you know if it is possible?
If ThisApplication.ActiveDocument.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then
    MessageBox.Show("This script only works on sheet metal (.ipt) files.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
    Return
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oCompDef As SheetMetalComponentDefinition = Nothing
Try
    oCompDef = oDoc.ComponentDefinition
Catch ex As Exception
    MessageBox.Show("This file does not have a defined sheet metal component.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
    Return
End Try
If oCompDef.HasFlatPattern Then
    Dim oFlatPattern As FlatPattern = oCompDef.FlatPattern
    Dim oRangeBox As Box = oFlatPattern.RangeBox
    Dim height As Double = oRangeBox.MaxPoint.Y - oRangeBox.MinPoint.Y
    Dim width As Double = oRangeBox.MaxPoint.X - oRangeBox.MinPoint.X
    If height > width Then
        MessageBox.Show("The height of the Flat Pattern is greater than its width.", "Notice", MessageBoxButtons.OK, MessageBoxIcon.Information)
    Else If width > height
        MessageBox.Show("The height of the Flat Pattern is not greater than its width.", "Notice", MessageBoxButtons.OK, MessageBoxIcon.Information)
	Else
Else
    MessageBox.Show("This file does not have a Flat Pattern defined.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
jnowel
You can access that property from FlatPatternOrientation Object
Dim pAngle As Inventor.Parameter = oFlatPattern.FlatPatternOrientations(1).AlignmentRotation
'Change angle to suit
pAngle.Expression = "0 deg"
