ilogic Question
ilogic Question
millenat1094
ilogic Question
millenat1094
Hello, I found this code on another form that rotates your appearance, like if you have a wood grain and want the direction to be different. Unfortunately, it keeps giving me the error "Object reference not set to an instance of an object."
I am not skilled enough to know what's going wrong here. Any help would be greatly appreciated 🙂 thanks!
Dim oDoc As PartDocument = ThisDoc.Document
Dim oAppearance As Asset = oDoc.ActiveAppearance
Dim oValue As AssetValue
For Each Value In oAppearance
    If oValue.ValueType = AssetValueTypeEnum.kAssetValueTextureType Then
        Dim oTextureAssetValue As TextureAssetValue = oValue
        Dim oTexture As AssetTexture = oTextureAssetValue.Value
        If oTexture.Item("unifiedbitmap_png").Value <> ""Then
              oTexture.Item("texture_WAngle").Value = TextureAngle
Next
PolemEngineering
Changing
For Each Value in oAppearance
in
For Each oValue In oAppearance
solves that error. What the rest of the code does is not entirely clear to me.
Code line 4 and 5 can also be combined like:
For Each oValue As AssetValue In oAppearance
René van der Starre
millenat1094
Thanks for your help. Unfortunately, the whole thing didn't work. I'm trying to get my textures to rotate with ilogic and can't seem to figure it out
WCrihfield
Hi @millenat1094.  That's a tough situation...and trying to fix it by code probably just multiplies the difficulty/complexity.  Digging into all of the different types and levels of AssetValue objects associated with an Asset object can be pretty challenging.  It is usually best to use an iLogic rule (or similar) to 'read' through all that data first, just to see what all is there, and what types of values they may have.  I have attached a text file containing some pretty complex iLogic code you can use in an iLogic rule (by itself) for inspecting all that data.  Then, once you are more familiar with all that, try to access the specific properties you want.  We can still do more manually, though the user interface dialogs, than we can by code in that area.
On a side note, there are a couple other curiosities I have come across, but have not yet explored into that much, but you may be able to look into if you are feeling inquisitive.
SurfaceBody.GetAppearanceTextureMappingData
SurfaceBody.SetAppearanceTextureMappingData
Face.GetTextureScale (I did not find a 'SetTextureScale' method)
Face.TextureMaps
TextureMaps
TextureMap
Wesley Crihfield
(Not an Autodesk Employee)
millenat1094
OKay, thank you for that. Altho i ran the rule and it did nothing. Is it putting that info into a text file? I tried to read though it but I am not very good at that yet
WCrihfield
No, it is supposed to write all that data into the iLogic Log window.  However, you must have had that 'iLogic Log' tab available before starting the rule, otherwise it will not be able to capture it.  To make sure that tab is visible, go to the View tab, then on the Windows panel, click the drop-down arrow by the 'User Interface' tool.  Then make sure the checkbox is checked next to the 'iLogic Log' option.
That should show a new tab next to your current 'iLogic' tab, and next to your 'Model' tab.  As long as that tab is visible (not necessarily active), then you run that rule, then you go to that tab and click on it (activate it), then you should see that a bunch of data has been written into that window area.  That window area is usually used for debugging and code related feedback information, but is also very convenient for writing other temporary data to, instead of writing it out to a separate text file.
Although, that is likely a lot of data, so writing it out to a text file would have probably been a better idea in this case.
Edit:  You may also need to make sure that your 'Log Level' is not set too low.  That setting can be found in 2 different places.  One is on the Tools tab, expand the Options panel down, then click on the iLogic Configuration tool.  In that small dialog, I usually keep my 'Logging' level set to Trace, which is the highest level (most detail), but keep the 'Detailed Trace' setting turned off (checkbox unchecked).  That Detailed Trace will write something into that window every single time a rule starts and finishes, which is usually not necessary, and can fill up that screen with relatively useless information.  The other place you can see and set those same settings is at the bottom of your iLogic rule editor dialog, when you are editing an iLogic rule.
Wesley Crihfield
millenat1094
Oh my, I had no idea that box even existed. That will help a lot! thank you for your help. I really appreciate it!
