check iproperties via excel
martinhoos
Message 1 of 14
martinhoos
Hi there,
i need your help, i am looking for some code that checks our assemblies. I have an assembly with maybe 3 parts (abcd-001, abcd-002 and abcd-003) in. Each of these parts has a part no stored in:
iProperties.Value("Summary", "Author")
And we have an excelfile, looks like this:
 How to check the assembly?
The code shouldt run to all parts and assemblys that are stored in the main assembly. look through the "part no" (Author) and find the part no in the Excel file. I need an Info via "messege"  if the Signalcode in the Excel file is 200 or 300
Hmmmm hard to explain....
Thanks in advance
Regards Martin
Replies (13)
Message 2 of 14
JaneFan
Hey Martin,
I am not sure if I get your point correctly. Do you store the part number information in "Summary\Author" property of each occurrence?
If so, please try following code with replacing some path and number:
SyntaxEditor Code Snippet
GoExcel.Open("xxx\Test.xlsx")
Dim doc = ThisDoc.Document
Dim strPN As String
For Each oDoc In doc.AllReferencedDocuments
'Get Summary->Author information of the document strPN = oDoc.PropertySets.Item(1).Item(3).Expression 'Change 6 to any number which indicates the row numbers in excel file For row = 1 To 6 Dim addr1 As String = "A" & Row Dim addr2 As String = "B" & Row Dim oa As Object = GoExcel.CellValue(addr1) Dim ob As Object = GoExcel.CellValue(addr2) If (oa.ToString() = strPN) Then If Int(ob) = 200 Or Int(ob) =300 Then errMsg = errMsg + String.Format("Large Values: row={0}, Name={1}, Value={2}", Row, oa, ob) MsgBox(errMsg) Exit For End If End If Next Next
Jane Fan
Inventor/Fusion QA Engineer
Message 3 of 14
martinhoos
Hi Jane,
thank you very much for your reply. Your code works exact what i was looking for - thank you!
Is it possible to Change the code a bit? If a part or an assembly is located via the Excel-sheet the color of it shouldt be change to red. I tried but without an result.
Component.Color(???) = "Red"
Thanks again...
Regards Martin
Message 4 of 14
JaneFan
Hey Martin,
ComponentOccurrence name is needed to set the appearance in top assembly:
GoExcel.Open("C:\TEMP\iLogicTest\GA\4\New folder\Test.xlsx")
Dim strPN As String
Dim oOcc As ComponentOccurrence
For Each oDoc As PartDocument In doc.AllReferencedDocuments
	'Get Summary->Author property information in the document
	For row = 1 To 6
			If Int(ob) = 200 Or Int(ob) = 300 Then
				For Each oOcc In doc.componentdefinition.occurrences
					If oOcc.definition.document Is oDoc Then
						Component.Color(oOcc.Name) = "red"
					End If
				Next
				errMsg = errMsg + String.Format("Large Values: row={0}, Name={1}, Value={2}", Row, oa, ob) + "; "
				MsgBox(errMsg)
				Exit For
			End If
		End If
	Next
Next
Jane Fan
Message 5 of 14
martinhoos
Hey Jane,
thanks again for your reply and for your help. Your code works very well - exact what i was looking for - thank you!
Very best Regards from Germany
Martin
Message 6 of 14
martinhoos
Hi Jane,
i have found a little mistake ... If i have a part in the assembly, that is not included in the Excel file, i get a message:
May be you can help me again?! I tried  with "try and catch" - but without result.  😞
Regards Martin
Message 7 of 14
JaneFan
Hey @martinhoos
I guess you are seeing the error might be caused by the row count in the excel is less than the number you set in this line:
For
row = 1 To 6
But Try and catch can avoid the error even though. I pasted part of the code with try catch:
 Try
 For row = 1 To 7
     End If
    Next
    MsgBox(errMsg)
    Exit For
   End If
  End If
 Next
 Catch
 End Try
Next
Jane Fan
Message 8 of 14
martinhoos
Hi Jane,
thank you very much for your reply. This solve my Problem.  😉
But i have another, hope "little problem", i get this message if i have an assembly shored in.
Hopefully you can help me again....  Thanks in advance.
Very best regards
Martin
Message 9 of 14
JaneFan
Hi Martin,
I see. 🙂
Please change this line:
To:
For Each oDoc As Document In doc.AllReferencedDocuments
Jane Fan
Message 10 of 14
martinhoos
Hi Jane,
thank you for your reply, this solves my problem. I changed the code a bit because it runs very slow. If i had about 20 parts and assemblys in, it will need 5:30 min.
In the excelfile i have 18.500 parts!
Is there a Change to Speed up the code?  Smiley Happy
myXLS=("c:\temp\check.xlsx")
GoExcel.Open((myXLS), "Tabelle1")
Dim strPN As String
	Try
	For row = 1 To 20000
					If oOcc.definition.Document Is oDoc Then
						Component.Color(oOcc.Name) = "Gesperrt_Signalcode"
					End If
				Next
				Exit For
		End If
	Next
	Catch
	End Try
Next
MessageBox.Show("Teile-Check ist fertig, evtl. gesperrte Artikel sind ROT gefärbt, bitte überprüfen.", "Check Signalcode")
Thanks in advance for your help.
Regards Martin
Message 11 of 14
JaneFan
Hey Martin,
There is a way to reduce one round of the loop since you don't need to control and show the message about which referenced documents being changed. Let's go through each component occurrence instead of referenced documents, so that we can use the occurrence name to set color directly in case of it fits the condition.
	strPN = oOcc.Definition.Document.PropertySets.Item(1).Item(3).Expression
Component.Color(oOcc.Name) = "Pink"
Next
It would probably quicker about 20 times, I guess. 🙂
Jane Fan
Message 12 of 14
martinhoos
Hi Jane,
thank you very much for your help.... If i changed the line you told me, Inventor runs not so Long but it changed all the parts to pink. May be i did a misstake. Please be so nice and üaste the hole code in.
Thanks a lot.....
Regards Martin
Message 13 of 14
JaneFan
Hello Martin,
How about this:
Dim strPN As String
	strPN = oOcc.definition.document.PropertySets.Item(1).Item(3).Expression
	MsgBox(doc.componentdefinition.occurrences.count)
	MsgBox(strPN)
	Try
	For row = 1 To 2000
				MsgBox(errMsg )
			End If
		End If
	Next
	Catch
	End Try
Next
Jane Fan
Message 14 of 14
martinhoos
Hi Jane,
thanks for your help... The code runs well.
Regards Martin
