Check if model is completely updated before running a rule
Good Day,
Does anyone know to check if a model is completely updated with ilogic?
I need to run another rule but specifically when the model is completely updated.
Shaun
WCrihfield
The PartDocument and the AssemblyDocument both have a property called RequiresUpdate that you could use to check with.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
