Running an Ilogic Rule at part level from Assembly
jorikvandermeer
jorikvandermeer
I'm having some trouble running an Ilogic code which normally functions at a part level. Firt i have to mention i'm not at al experienced with Inventor, let alone ILogic.
I've browsed through some forum posts and got a Ilogic code for an Oriented Rangebox working at the part level. I've created this as an external rule, which runs with a Macro button. The dimensions are written as Iproperties to the part in question. These dimensions can later be used in the BOM and cutting list.
The company i'm working at produces custom (semi-) trailers. When designing a new trailer, the structural members are often custom made, with seperate steel plates and stips.
Normally we'll make a Master Sketch, which is projected to the seperate parts in the assembly. So my goal is to be able to edit the part, within the parent assembly and run the rule from there. Instead of opening each part and run the rule.
With kind regards,
Jorik
Ralf_Krieg
Hello
Is there something like
Dim oDoc as PartDocument = ThisApplication.ActiveDocument
in your code. The active document is the assembly in this case. You can try to change this line to
Dim oDoc as PartDocument = Thisapplication.ActiveEditDocument
For further help you need to post relevant parts of your code.
R. Krieg
RKW Solutions
www.rkw-solutions.com
jorikvandermeer
Works like a charm!
Thanks a lot!
