Check if flat pattern is different from folded model (using VB.net/ VBA)
Message 1 of 1
I need to check if the flat pattern model is different from the folded model. For example you can create a flat pattern from a plate and both look the same.
Why? I want to automatically create a flat pattern from every sheet metal model, but not from models with identically flat patterns.
Thank you!
Replies (0)
