i am using below code to get dimension text back to center. But my problem is that i just want to do text in center only selected Dimesions ..NOT ALL Dimesion in sheet. Below code re-set all the dimesions. Could any body help me in this regard. Thanks, Belash Sub DimensionArrange() ' Set a reference to the active drawing document Dim oDoc As DrawingDocument Set oDoc = ThisApplication.ActiveDocument ' Set a reference to the active sheet Dim oSheet As Sheet Set oSheet = oDoc.ActiveSheet Dim oDrawingDim As DrawingDimension ' Iterate over all dimensions in the drawing and ' center them if they are linear or angular. For Each oDrawingDim In oSheet.DrawingDimensions If TypeOf oDrawingDim Is LinearGeneralDimension Or _ TypeOf oDrawingDim Is AngularGeneralDimension Then Call oDrawingDim.CenterText End If Next End Sub
