Changing Line Colors for Individual Parts in Drawing Views With iLogic
dusan.naus.trz
Advisor Advisor
dusan.naus.trz
I found the code for VBA on the forum
I wanted to modify this code for iLogic, but I can't do it at all, I'm constantly getting bugs or nothing.
Original Code for VBA is OK
Sub ChangePartColor()
    Dim oDoc As DrawingDocument, partStr As String
    If ThisApplication.ActiveDocumentType <> kDrawingDocumentObject Then
        Call MsgBox("This macro only works on drawing documents.")
        Exit Sub
    End If
    Set oDoc = ThisApplication.ActiveDocument
    partStr = InputBox("Part to color:", "Prompt")
    Dim oTrans As Transaction, i, j, k, c
    Dim ViewCurves As DrawingCurvesEnumerator, refAssyDef As ComponentDefinition, oColor As color
    Set oColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0) 'RGB
    Set oTrans = ThisApplication.TransactionManager.StartTransaction(ThisApplication.ActiveDocument, "Colorize [PART]")
        For Each i In oDoc.Sheets
        For Each j In i.DrawingViews
            If j.ReferencedDocumentDescriptor.ReferencedDocumentType = kPresentationDocumentObject Then
                Set refAssyDef = j.ReferencedDocumentDescriptor.ReferencedDocument.ReferencedDocuments(1).ComponentDefinition
            ElseIf j.ReferencedFile.DocumentType = kAssemblyDocumentObject Then
                Set refAssyDef = j.ReferencedFile.DocumentDescriptor.ReferencedDocument.ComponentDefinition
            End If
            For Each k In refAssyDef.Occurrences
                If k.name Like partStr & ":*" Then
                    Set ViewCurves = j.DrawingCurves(k)
                    For Each c In ViewCurves
                        c.color = oColor
                    Next
                End If
            Next
        Next
    Next
    oTrans.End
End Sub
That's how I changed it, but it still doesn't work for me. I think the error is on this line = Dim oTrans As Transaction
iLogic = doesn't work
Sub Main()
	Dim partStr As String
        Exit Sub
    End If
	Dim refAssyDef As ComponentDefinition
	Dim oColor As Color
            End If
                If k.Name Like partStr & ":*" Then
                        c.Color = oColor
                    Next
                End If
            Next
        Next
    Next
    oTrans.End
End Sub
JelteDeJong
in iLogic exception handling is done different from vba. in vba you have "OnErrorResume next" (could be written a bitt difference. not an expert on VBa) in iLogic you need to use Try/Catch blocks.
try this:
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
    Exit Sub
End If
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim partStr As String = InputBox("Part to color:", "Prompt")
Dim oColor As Color = ThisApplication.TransientObjects.CreateColor(255, 0, 0) 'RGB
Dim oTrans As Transaction = ThisApplication.TransactionManager.StartTransaction(ThisApplication.ActiveDocument, "Colorize [PART]")
For Each sheet As Sheet In oDoc.Sheets
    For Each view As DrawingView In Sheet.DrawingViews
        If View.ReferencedDocumentDescriptor.ReferencedDocumentType = DocumentTypeEnum.kPresentationDocumentObject Then
            refAssyDef = View.ReferencedDocumentDescriptor.ReferencedDocument.ReferencedDocuments(1).ComponentDefinition
        ElseIf View.ReferencedFile.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
            refAssyDef = View.ReferencedFile.DocumentDescriptor.ReferencedDocument.ComponentDefinition
        End If
        If (refAssyDef Is Nothing) Then
            Continue For
        End If
        For Each occurrence As ComponentOccurrence In refAssyDef.Occurrences
            If occurrence.Name Like partStr & ":*" Then
                Try
                    Dim ViewCurves As DrawingCurvesEnumerator = View.DrawingCurves(occurrence)
                    For Each c As DrawingCurve In ViewCurves
                        c.Color = oColor
                    Next
                Catch ex As Exception
                End Try
            End If
        Next
    Next
Next
oTrans.End()
Jelte de Jong
Blog: hjalte.nl - github.com
dusan.naus.trz
It works great. Thank you very much for your help. I am sending the result to others as well. Attached video.
julien.avril
Bonjour
Avez-vous la variante avec les sous-niveau ? car ca ne fonctionne pas avec les pièces sous un assemblage?
Exemple ci-dessous:  ca fonctionne avec module mais pas avec planche qui ce trouve sous l'assemblage module
