Changing Leader Text Justification throws unexpected results
Hi all,
I'm having problems editing Leader Notes with VBA. I've written code which replaces all our LeaderNotes and Balloons with the same object which has slightly different properties (namely, the leader colour and lineweight). Now my problem is that when I adjust the verticle justification of a LeaderNote, then the colour property is disturbed. By default, our LeaderNotes have colour = ByLayer. However once I change the Verticle Justification, then the colour is changed to Black by Override.
I'm using this code to change the justification
newLeader.VerticalJustification = oldLeader.VerticalJustification
 And I tried using this code to manually fix the colour
        Set clrColor = ThisApplication.TransientObjects.CreateColor(0, 0, 0)
        clrColor.ColorSourceType = kLayerColorSource
        newLeader.Color = clrColor
 but nothing is working... It's driving me mad, does anyone have any suggestions???
YuhanZhang
How about use below line instead of creating a totoally new color:
Set clrColor = oldLeader.Color
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Hi Rocky,
Thanks for the suggestion.
I had tried to change the colorsourcetype using that same method, but that didn't work. I've just tried your suggestion now, and it still doesn't work.
Here's a code example you could try on any drawing with any leader note.
Sub LeaderJustificationTest()
Dim oDoc As DrawingDocument
Dim oLeader As LeaderNote
Set oDoc = ThisApplication.ActiveDocument
For Each oLeader In oDoc.ActiveSheet.DrawingNotes.LeaderNotes
    oLeader.VerticalJustification = kAlignTextLower
    oLeader.Color = clrColor
Next oLeader
End Sub
Try running that, and once it's done check the color to see if it's "ByLayer"... Mine isn't...
Cheers
YuhanZhang
Yes, the code reproduces the issue, I logged this issue, please provide the number 1413808 to us to check the status. If you need a hotfix for this issue please provide your business case to Autodesk ADN.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
