export bom with different order
skyngu
Message 1 of 9
skyngu
hi,
I use vba to export bom to excel. But the orders are different from using "export buttom" in BOM. The "description" is at the front. anyone knows why?
spec: inventor 2011 & windwo 7
thanks
Autodesk Inventor Professional 2027
Replies (8)
Message 2 of 9
skyngu
Is this a bug? I tried few times. The order of columns are different. Thanks
Public Sub BOMExport()
 Dim oAssy As AssemblyDocument
 Set oAssy = ThisApplication.ActiveDocument
' Set a reference to the BOM
 Dim oBOM As BOM
 Set oBOM = oAssy.ComponentDefinition.BOM
'Set file save path & temp picture
 Dim sPath As String
 sPath = Left(oAssy.FullFileName, Len(oAssy.FullFileName) - 4) & ".xls"
' switch structured view to all levels or first level only
 oBOM.StructuredViewFirstLevelOnly = True
' Make sure that the structured view is enabled.
 oBOM.StructuredViewEnabled = True
' Set a reference to the "Structured" BOMView
 Dim oStructuredBOMView As BOMView
 Set oStructuredBOMView = oBOM.BOMViews.Item("Structured")
' Export the BOM view to an Excel file
 oStructuredBOMView.Export sPath, kMicrosoftExcelFormat
end sub
Message 3 of 9
skyngu
anyone has the same problem?
Message 4 of 9
Yeah, I had the same problem. It looks to sort the columns in alphabetical order. So I had to wirte some code to sort it the way i want after the Excel file is generated.
Dan
Message 5 of 9
skyngu
but it is fine in inventor 2010.
Message 6 of 9
I know but it's this way in 2011 and 2012. I don't understand why it was changed to that. Hopefully it will be fixed in a service pack or hotfix but don't count on it. In the meantime, here is what I used to get my code to work. I am only using the Item, Component Type, Part Number, Qty, and Description columns. This will sort it in that order.
    Public Sub RearrangeColumns(ByVal strExcelFileName As String)
        Try
            oExcelApp = GetObject(, "Excel.Application")
        Catch ex As Exception
            oExcelApp = CreateObject("Excel.Application")
            oExcelApp.Visible = False
        End Try
        Dim oBook As Workbook
        Dim oSheet As Worksheet
        oBook = oExcelApp.Workbooks.Open(strExcelFileName)
        oSheet = oBook.WorkSheets(1)
       'cut the item and paste it at the beginning
        oSheet.Columns("C:C").select()
        oExcelApp.Selection.cut()
        oSheet.Columns("A:A").Select()
        oExcelApp.Selection.Insert(Microsoft.Office.Interop.Excel.XlDirection.xlToRight)
       'cut the Part number and paste it as the 3rd column
        oSheet.Columns("D:D").select()
        oSheet.Columns("C:C").Select()
        'cut the Qty and paste it as the 4th column
        oSheet.Columns("E:E").select()
        oSheet.Columns("D:D").Select()
        oBook.Save()
        oExcelApp.Visible = True
    End Sub
Hopefully that helps.
Message 7 of 9
stupid formating. The smiley faces are suppose to be a colon and the letter D.
Message 8 of 9
skyngu
thanks for your reply.
I hope there will be a patch from autodesk soon.
Message 9 of 9
Hello, I have found this same problem in Inventor 2015. Exported columns are sorted alphabetically when exporting, even after importing a .styxml style.
Is this patch still planned for release?
