Changing Iproperties material in a part
JorisSteurs1246
Message 1 of 12
JorisSteurs1246
I want to change the part material trough an iLogic form.
The code below reads the available materials and puts them in a multivalue list.
The problem I have is that the rule doen't make the part material change to what I've selected in from the multivalue list.
Please Help.. Man Sad
SyntaxEditor Code Snippet
Try
Sl = Parameter.Param("SheetMetalType")
Catch
oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
oParameter=oMyParameter.AddByValue("SheetMetalType","undefined", UnitsTypeEnum.kTextUnits)
 End Try
Dim smStyleList As New ArrayList
For Each smStyle As SheetMetalStyle In ThisDoc.Document.ComponentDefinition.SheetMetalStyles
    smStyleList.Add(smStyle.Name)
Next smStyle
Parameter.Param("SheetMetalType").Comment = "Parameter set by Rule -- RunOnSheetMetal-- "
MultiValue.List("SheetMetalType") = smStyleList
Try
 p = Parameter.Param("Partmaterial")
Catch
oParameter=oMyParameter.AddByValue("Partmaterial","Steel, Mild", UnitsTypeEnum.kTextUnits)
 End Try
MultiValue.List("Partmaterial") = iProperties.Materials
RuleParametersOutput()
iLogicVb.UpdateWhenDone = True
iProperties.Material = Partmaterial
Parameter.Param("Partmaterial").Comment = "Parameter Set by Rule -- RunOnSheetMetal-- "
Replies (11)
Message 2 of 12
I've something at work that should achieve this. If nobody posts a solution I'll help you out if I can on Monday.
Message 3 of 12
Mike.Wohletz
Add the below to the end of your list and it should work just fine.
Dim osmCompDef As SheetMetalComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
                                For Each s As SheetMetalStyle In osmCompDef.SheetMetalStyles
                                    If s.Name = SheetMetalType Then
                                        s.Activate()
                                Next
Message 4 of 12
JorisSteurs1246
HI Mike,
Thanks for looking in to this.
Your suggestion to add your bit of code is not helping.
The reason is most likely because it is dealing whith the sheetmetal style.
Sheetmetal style selecting is working ok already.
It is the part material selecting that doesn't make the changes on the part.
The rule also gives an error ( see attachment)
Joris
Message 5 of 12
I created the multi value list allowing custom values then created this rule to show the form and allocate the material.
Maybe you can use this in your code somewhere?
iLogicForm.Show("CONFIGURATION", FormMode.NonModal)
MultiValue.List("MATERIAL") = iProperties.Materials
iProperties.Material=MATERIAL
Trigger=iTrigger0
Now when the form is used to select the material it updates to the part.
It is probably obvious that I am no expert but it seems to work fine and I hope this helps in some way.
Message 6 of 12
JorisSteurs1246
Thanks for your contribution 🙂
Your line of code is what I have also, but it is not working for me .
I added the triggers as you have but it made no change, I still get the
same error message.
Message 7 of 12
Sorry about that I've been running this for some time now without any issues. Maybe somebody more knowledgeable than me can tell you why there is an error?
Sorry I couldn't be of any help.
Message 8 of 12
JorisSteurs1246
No Worries,
All attempts to help are very much appreciated , even if they were not
successful it will hopefully help me to narrow down the problem.
Joris
Message 9 of 12
Mike.Wohletz
I guess I dont see what part is not working as the posted code does not change the SheetMetal defaults and the material type does change so I have posted a solution for the part that does not work. can you tell us what version of Inventor you are using?
see Screencast included in this post.
http://autode.sk/1I6efWB
Message 10 of 12
MechMachineMan
Does swapping between flat pattern and folded model make a difference?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 11 of 12
JorisSteurs1246
No, folded or unfolded state of the sheetmetal part gives the same error.
Message 12 of 12
JorisSteurs1246
Hi Mike,
The way you show it in the screencast is exactly what I' aiming for.
Happy to seeing it working.
I'm using AI2015-PRO
I can see you get the same error, but that nevertheless, after ignoring the error the part will adjust the material after selection of the material in the form.
The only difference I'm doing here is that both the rule and the form that is used are global.. nothing local like in your screencast.
Do you get the same result when setting everything as global?
Thank you so much for your contribution so far,
Joris
