Mensaje 1 de 6
Changing a User Parameter in an assembly
No aplicable
04-01-2003
11:32 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have a part file ("part1.ipt") that has a user parameter called "Height". When I open this file as a part document, I can modify the "Height" parameter to change the height of the part. This functionality works great:
Set oPartDoc = oApp.Documents.Open(sPartFileName, True)
Set oParameters = oPartDoc.ComponentDefinition.Parameters
'change part height to 30 cm
oParameters.Item("Height").Expression = 30
Now, I am wanting to add this part to an ASSEMBLY document, then change the parameter to 30, but have been unable to do it.
I have this so far:
Dim oAsmCompDef As AssemblyComponentDefinition
Set oAsmCompDef = oApp.ActiveDocument.ComponentDefinition
Dim oOcc As ComponentOccurrence
Set oOcc = oAsmCompDef.Occurrences.Add(sPartFileName, oMatrix)
After I add all the parts, I highlight a part in the assembly pane, I click on FxParameters but I don't see the User Parameters for the part. Are the User Parameters not available when a part is placed into an assembly?
This assembly will have multiple parts added from the same file name, but the "Height" parameter needs to be modified for each occurence.
Can anyone give me some direction on how to change these types of parameters?
tia,
clu
I have this so far:
tia,
clu
