Accessing Sketch and Part Object In Assembly
What I'm trying to do is make a program that will insert our company's
standard hole sizes nto a part or into an edited part in an assembly file.
Some background info on how it should work. The user puts a sketch on a
plane or planar surface and draws hole points where they want. They run the
hole program and the program iterates through tht open sketch finds the hole
points and adds the holes and closes the sketch. The code I have below
works fine for a part file, but when I am editing a part in an assembly
file, as soon as I try to get the selectset or anything else from the edited
part it crashes. I have checked the enumeration value of the of the
document type object in both cases and they both return
kPartDocumentObject. The program seems to fail in the selPoints function
where I check if the user has selected anything and add the hole points to
an object collection. My main question is has anybody done something
similar either in VB or in VC++ and got it to work for both a single part
and a part in an assembly? Any help would be appreciated
Josh
// Getting the active document.
CComPtr pDoc;
CComQIPtr pAssyDoc;
CComQIPtr pPartCompDef;
CComPtr pHolePoints;
HRESULT hr = m_pApplication->get_ActiveDocument(&pDoc);
if (FAILED(hr))
AfxMessageBox(_T("m_pApplication->get_ActiveDocument Failed!"));
return hr;
// Checking document type.
DocumentTypeEnum docType;
pDoc->get_DocumentType(&docType);
// Is the active document a part document.
if(docType == kPartDocumentObject)
pPartDoc = pDoc;
// Getting component definition.
hr = pPartDoc->get_ComponentDefinition(&pPartCompDef);
if(FAILED(hr))
AfxMessageBox(_T("pPartDoc->get_ComponentDefinition Failed!"));
return hr;
else if (docType == kAssemblyDocumentObject)
CComPtr pAssyCompDef;
CComPtr pActiveOcc;
pAssyDoc = pDoc;
hr = pAssyDoc->get_ComponentDefinition(&pAssyCompDef);
if (FAILED(hr))
AfxMessageBox(_T("get_ComponentDefinition Failed!"));
return hr;
hr = pAssyCompDef->get_ActiveOccurrence(&pActiveOcc);
if (FAILED(hr))
AfxMessageBox(_T("get_ActiveOccurrence Failed!"));
return hr;
DocumentTypeEnum assyDocType;
pActiveOcc->get_DefinitionDocumentType(&assyDocType);
if(assyDocType == kPartDocumentObject)
CComPtr pCompDef;
hr = pActiveOcc->get_Definition(&pCompDef);
if(FAILED(hr))
return hr;
pPartDoc = pActiveOcc;
pPartCompDef = pCompDef;
// Get selection and add holes.
hr = selPoints(pHolePoints);
if(FAILED(hr)) return hr;
Josh,
This was an interesting problem. Below is some code that I think does what
you want. I ran into one issue with Inventor not returning from the sketch
environment after creating the feature. I've logged a defect for this but
was also able to workaround it by calling the "Return" command explicitly.
Public Sub CreateHoles()
' Check to see that a sketch is the active edit object.
Dim oSketch As PlanarSketch
If TypeOf ThisApplication.ActiveEditObject Is PlanarSketch Then
' Check to see that the sketch is in a part document and not an
assembly.
' This is because assembly features are not currently supported.
If TypeOf ThisApplication.ActiveEditObject.Parent Is
PartComponentDefinition Then
Set oSketch = ThisApplication.ActiveEditObject
Else
MsgBox "A part sketch with hole centers must be active."
Exit Sub
ElseIf TypeOf ThisApplication.ActiveEditObject Is PartDocument Then
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveEditObject
If TypeOf oPartDoc.ActivatedObject Is PlanarSketch Then
Set oSketch = oPartDoc.ActivatedObject
Else
Exit Sub
Else
Exit Sub
' Find all of the hole centers on the sketch and add them to the
collection.
Dim oHoleCenters As ObjectCollection
Set oHoleCenters =
ThisApplication.TransientObjects.CreateObjectCollection
Dim oPoint As SketchPoint
For Each oPoint In oSketch.SketchPoints
If oPoint.HoleCenter Then
oHoleCenters.Add oPoint
Next
' Create the hole feature.
Dim oPartCompDef As PartComponentDefinition
Set oPartCompDef = oSketch.Parent
Call
oPartCompDef.Features.HoleFeatures.AddDrilledByDistanceExtent(oHoleCenters,
2, 2, kPositiveExtentDirection)
' When editing a part in-place within an assembly, it's not correctly
' exiting the sketch environment when the feature is created. This
' forces the exit.
If ThisApplication.ActiveDocumentType = kAssemblyDocumentObject Then
ThisApplication.CommandManager.[_StartCommand] 44011
End Sub
-Brian
"Josh Tiffin" wrote in message
news:E214B43F7DDE923EB16DA791CE50CE7B@in.WebX.maYIadrTaRb...
the
hole
edited
> Josh
> CComPtr pDoc;
> CComQIPtr pAssyDoc;
> if (FAILED(hr))
> return hr;
> pPartDoc = pDoc;
> if(FAILED(hr))
> return hr;
> CComPtr pActiveOcc;
> pAssyDoc = pDoc;
> if (FAILED(hr))
> return hr;
> if (FAILED(hr))
> return hr;
> CComPtr pCompDef;
> if(FAILED(hr))
> return hr;
Brian
Thanks for the response. I managed to put together something that works,
below is the code. It probably isn't the most elegant solution but it does
what it needs to do. There is still some error checking to be done and some
other functionality to be put in. I don't know if this is the best solution
for I'm pretty much a hack at C++ programming. Is there any documentation
that is geared more toward VC++ than VB?. There really is a lack of API
documentation for VC++ programers.
Josh
CComPtr pDoc;
CComPtr pPartCompDef;
if (FAILED(hr))
return hr;
// pPartDoc is defined in header file and is defined as
CComQIPtr pPartDoc;
pPartDoc = pDoc;
if(FAILED(hr))
return hr;
// Getting assembly document
CComQIPtr pAssyDoc(pDoc);
CComPtr pObject;
// Getting part document
hr = pAssyDoc->get_ActivatedObject(&pObject);
pPartDoc = pObject;
pPartDoc->get_DocumentType(&assyDocType);
// Checking document type and making sure it is a part
if(FAILED(hr))
return hr;
// This function iterates through the sketch and get all the hole points.
// Returning from sketch
// Getting the object.
CComPtr pObject;
hr = pPartDoc->get_ActivatedObject(&pObject);
if (FAILED(hr)) return hr;
// Checking for an active sketch
if(pPartDoc->SketchActive)
CComQIPtr pSketch(pObject);
// Close the sketch.
hr = pSketch->ExitEdit();
"Brian Ekins (Autodesk)" wrote in message
news:0C651197A67B39AF40D6D9120D5E809A@in.WebX.maYIadrTaRb...
> Josh,
what
sketch
> assembly.
> Else
> Exit Sub
> End If
> Else
> Exit Sub
> End If
> Else
> Exit Sub
> End If
> collection.
> Set oHoleCenters =
> End If
> Next
> Call
> ' forces the exit.
> End If
> End Sub
> -Brian
file.
> the
> hole
> edited
function
to
part
> > Josh
> > CComPtr pDoc;
> > CComQIPtr pAssyDoc;
> > if (FAILED(hr))
> > return hr;
> > pPartDoc = pDoc;
> > if(FAILED(hr))
> > return hr;
> > CComPtr pActiveOcc;
> > pAssyDoc = pDoc;
> > if (FAILED(hr))
> > return hr;
> > if (FAILED(hr))
> > return hr;
> > CComPtr pCompDef;
> > if(FAILED(hr))
> > return hr;
There is a lot of documentation we still want to write. The intent is that
the overviews will use VBA, but we want to have a section on general
practices using C++ and how to perform certain operations using C++, such as
using arrays, strings, events, etc.
-Brian
news:1487C70E2575A4E34F00F01125EE87D5@in.WebX.maYIadrTaRb...
> Brian
does
some
solution
> Thanks
> Josh
> CComPtr pDoc;
> if (FAILED(hr))
> return hr;
> CComQIPtr pPartDoc;
> pPartDoc = pDoc;
> if(FAILED(hr))
> return hr;
> CComPtr pObject;
> pPartDoc = pObject;
> if(FAILED(hr))
> return hr;
points.
> CComPtr pObject;
> > Josh,
> what
> sketch
but
explicitly.
> > assembly.
> > Else
> > Exit Sub
> > End If
> > Else
> > Exit Sub
> > End If
> > Else
> > Exit Sub
> > End If
> > collection.
> > Set oHoleCenters =
> > End If
> > Next
> > Call
correctly
> > ' forces the exit.
> > End If
> > End Sub
> > -Brian
> file.
a
run
> > the
the
> > hole
below
assembly
> > edited
> function
points
> to
> part
> > > Josh
> > > CComPtr pDoc;
> > > CComQIPtr pAssyDoc;
> > > if (FAILED(hr))
> > > return hr;
> > > pPartDoc = pDoc;
> > > if(FAILED(hr))
> > > return hr;
> > > CComPtr pActiveOcc;
> > > pAssyDoc = pDoc;
> > > if (FAILED(hr))
> > > return hr;
> > > if (FAILED(hr))
> > > return hr;
> > > CComPtr pCompDef;
> > > if(FAILED(hr))
> > > return hr;
