Change thread standard on an existing bolt family in content center
rb
rb
We are currently on Inventor and Vault 2020.
I couldn't find a standard library for stud bolts with UNC/8UN threads and therefore my plan was to copy one of the DIN libraries for studs and change the details to match with my requirements.
However, it seems like I can't change the thread type and size from METRIC to UNC/8UN.
Therefore I am curious to learn how to proceed. I could certainly keep the bolts as METRIC and simply change the description on them, but that is cheating and if I for any reason need to call-out the thread in the model or drawing I presume it will still show as METRIC?
Your feedback is highly appreciated.
bradeneuropeArthur
create a normal part and add that thread you need.
Now copy exact this name into you family table.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
